Tip & How-To about Sennheiser HD 25 Professional Headphones
EAR PIECE PADS
HOW DO I CHANGE THE EAR PIECE PADS.
Sennheiser HD 25 Professional Headphones Logo
changed front brake pads and still has a grinding sound and vibration
This is why in North America they always change pads and rotors at the same time. Have you hit a kerb in bad weather? The grinding sound may be bad wheel bearings or CV Joints. Jack the front of the vehicle up and spin the wheels. Put a piece of polythene pipe in your ear and use it to pinpoint where the grinding noise is coming from. It looks odd, but it works.
Mar 09, 2016 | Cars & Trucks
How to replace ear pads?
If you use a headset frequently, it's important to change the ear cushion periodically. Ear cushions absorb a lot of sweat, dirt and makeup and can breed bacteria if not cleaned or replaced as necessary. This can lead to bacterial ear infections in extreme cases. Repeated and frequent use can also cause foam ear cushion to deteriorate and break into pieces over time.
portable mp3 player
Sep 11, 2012 | Sennheiser Ear Pad Hd497 Hd202 Ii Hd212...
bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
2,105 people viewed this tip
Top Sennheiser Audio Players & Recorders Experts
Vito Vacirca Jr.
Gerhardus Stroebel
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
