Tip & How-To about Office Equipment & Supplies
How to install a printer without the install cd.
You lost, broke or damaged your installation cd for your printer and the software is corrupt and needs reinstalled or you want to hook it to a different computer. What should you do?
You can install a printer without the cd.
First connect the printer to the USB port if that is how it hooks up, this is the most common hookup. Power the printer on. Give the computer, which should already be running, some time to recognize the printer. It will ask for the disk (cd) or if you want to browse for it. Cancel the setup at this time.
Google your printers brand. Go to the company web site. You should see a link to 'drivers and downloads' click on this. A page will open usually with a search engine. Input your model. You should be presented with software for your model printer to download. Follow the instructions and download the software to your desktop.
When done close the internet and click on the software you just downloaded. It should start an install. Follow the instructions and install the software. Reboot your computer and go to the printer setup. Find your printer and open the maintenance menu. You should be able to do a test print at this point. If your printer prints a test page you are done.
I would save the downloaded software to a file which you can easily recognize and burn it on a cd.
Thanks for using FixYa and for the great rating.
hardrocko
LEXMARK PRINTER X4650 OCR folder not found
The scan software(OCR) may not be installed in the computer or probably got corrupted. Reinstall the software. The Lexmark scan software(OCR) can only be installed using the installation cd that came with the printer. It's not available online for download since it's a big file. If you don't have it or you lost it, I suggest you contact Lexmark Technical Support for assistance.
May 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
missing all in one program
The All-in-One software might be corrupted or not installed properly. Try to reinstall it. The software can only be installed using the installation cd. The Lexmark All-in-One software is not available for download online since it's a big file. If you don't have the cd or you lost it, I suggest you contact Lexmark Technical Support. They can send you one for free.
May 02, 2010 | Lexmark X2250 All-In-One InkJet Printer
service error software required.where do I find it?
reinstall your printer driver to repair the damage or corrupt one. If you have CD Driver in your printer then insert it in your DVD/CD ROM and reinstall your printer driver else if you on't have the CD Driver then download here: Epson Stylus Driver
If you  need more assistance just reply to this post.  Thanks
Jun 26, 2009 | Epson STYLUS R230 InkJet Photo Printer
installing a printer
Click on this link. Pick your operating system & download your drivers. http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
To be honest if your driver software was running before you had the CD burner repaired you should not need to re-install Your printer. However if you think you need to re-install please uninstall previous software. Open control panel, open Add /Remove Programs. Find your Printer & un-install it. Re-start your Pc & hook up your printer & re-install the software.
We at FixYa try to help people. So if there was a problem with your CD burner why would any repair site need your whole computer including your printer? You don't need to answer that.
The average CD burner, brand new runs between $20.00 & 30.00 & I'm showing a DVD/RW burner that also burns CD's.
Feb 15, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
941 people viewed this tip
k24674
jasbo
jasbo
