Tip & How-To about Computers & Internet
How to charge your new replacement battery
When charging the Toshiba satellite l200 battery for the first time your device may indicate that charging is complete after just 10 minutes or 15. This is a normal phenomenon with rechargeable batteries. Simply remove the battery from the computer and repeat the charging procedure.
Not to do so may significantly shorten the life of the Battery Sony vgp-bps9a/b (This does not apply to Li-ion batteries, which do not require conditioning). To discharge, simply run your unit under the power of the Battery Toshiba pa3399u 2brs until it stops or until you get a warning Battery low. Then recharge the Battery as indicated in your owner's manual.
If the laptop Battery will not be used for a month or more, it is recommended that it be removed from theunit and stored in a cool, dry and clean.
It is normal for a Battery become hot during loading and unloading. A Compaq Presario V2000 battery Authority will eventually lose its charge if unused. It may therefore be necessary to recharge the Battery after a storage period.
The milliamp-hour (mAh) rating of Notebook Battery dot org is often higher than your Battery of origin. An index above Mah is indicative of a longer duration (more capacity) of the Pavilion DV9000 battery and will not cause any incompatibilities. A Battery Laptop Battery dot org, in most cases better than the original 30% to 50%.
How the pa3451u 1brs Battery in real time depends on the power demand made by the equipment. In the case of laptops, the use of the screen, the disk drive and other devices results in an additional drain on the Battery, Effectively managed by reducing the BatteryTime. The total running time of ThinkPad x30 battery is also heavily dependent on equipment design. To ensure maximum performance of the laptop battery, optimize power devices on your computer management. Refer to your computer manual for further instructions.
Computers & Internet Logo
my battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
"Plugged in, not charging", Toshiba Satellite A135 S4527, under Windows Vista Home Premium
It sounds like the power socket on the laptop is faulty and needs replacing or resoldering. To check this, power up the latop with the power adapter, wriggle the plug in the power socket and check if the battery charge indicator flicks on and off indicating charging and not charging. If it indicator flicks on and off then you have a faulty power socket.
This can be repaired but required the laptop to be completely dismantled to access the power connector.
Feb 18, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
battery problem
Get rid of the "Satellite". I have had the same problem with two new batteries. Not good.
Sep 07, 2008 | Toshiba Satellite A135-S4467 Notebook
180 people viewed this tip
David Payne
David Payne
