Tip & How-To about Computers & Internet
Tips Phones - MP3 Players to gain autonomy
Your phone or MP3 player or any device Compaq presario cq60 battery is normally technoloogical lithium-polymer. They are useful for about 500 charges. Only 500, you ask? Charing is a cycle where the battery is completely empty. There is no limit to the number of times you can rechagre a capacity of 50%.
If you recharge your Phone, Mp3 Compaq evo n410c battery every two days. 500 charges, on average, should last you almost 3 years.
Here are some tips to increase the lifespan of the Acer Aspire 5000 battery.
  • Do not let the battery die completely.
If you want to get the most from your Dell XPS M1210 battery life. Do not allow the discharge of 100% until she died. However little you use your Phone, reader MP3, recharge once every three weeks to prevent the Apple a1080 battery from going flat. If you go on vacation for a month, you should take your Phone or reader MP3 with you and recharge it.
  • Try reducing the power required.
A car with air con will consume more fuel. A Phone or Mp3 with ligh, when you're in the day will use more energy. On an iPod, this is called "backlight" that can easily be disabled. You do not sound too high. The higher the more energy it uses.
Computers & Internet Logo
how long will my 4gb go gear take to chaarge
Your Go Gear uses one lithium polymer battery and has an 800mAH battery. That should have a full charge in less than three hours. If it doesn't charge by then your battery has worn out and needs to be replaced.
Zashiban
May 31, 2010 | Philips GOGEAR SA6045 MP3 Player
i plug my sansa clip 2gig into a ps2 to charge with a usb cord and it looks like its charging but when i take it off the usb cord the battery is still dead
The internal rechargeable is obviously not retaining the current: if the device is around 18months or has been in heavy use (around 500 charges), the Li-Ion/Li-Polymer battery is well past its useful life and needs to be replaced. It may of course be really defective! Unless you can perform this delicate operation yourself, the cost to replace the internal battery may not be justifiable.
Dec 18, 2009 | SanDisk Sansa Clip MP3 Player
My Compaq Presario CQ60 charger will not charge
try diffrent charger or try to turn on ur laptop with out the battery might be a problem with charger or battery
Aug 16, 2009 | HP Compaq Presario CQ60-249US Notebook
Batteries
The Lithium batteries that are provided with the camera will supply approximately 200 images. The Ni-MH batteries will provide approximate 100 shots per charge. The B-10LPB Lithium Polymer battery will allow 500 - 700 shots per charge and can be recharged approximately 500 times. B-12LPB Lithium Polymer Battery will deliver twice the power allowing 1000- 1400 shots per charge and can be recharged approximately 500 times. The Alkaline batteries, although can be used, is not recommended due to very low battery life.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
126 people viewed this tip
David Payne
David Payne
