Tip & How-To about Kitchen Appliances - Others
How to fix a stuck garbage disposal
On the bottom of the canister (there should be a reset button)
find it and press it.
if this doesn't work then there is also a small hole where you can insert an allen wrench (hex key) and manually turn the motor. If there is something caught in there this should get it loose
Kitchen Appliances - Others Logo
How do i reset a V-Touch?
Welcome to Fixya. To reset V-touch press the reset button which is located on the back in the bottom left corner of the player
Thanks
Sep 28, 2011 | Visual Land V-Touch Digital Media Player
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
how do i get it to work
Hook the power cord to it, press the small button below the screen on the left side. If nothing, then flip it over on it's back and find a small hole 1in. from the right diagonal bottom of the data plate. It has RESET as marking. Insert a tooth pick into the small hole and press down for about 5 seconds.
Jan 01, 2011 | Sylvania G-Netbook
I can´t reset the modem D-Link 2320-B, I am trying
You can restore the unit to factory setting by pressing the reset button. It is located inside a small hole on the back of your router between the LAN and DSL connections. You'll need a pin or very small screwdriver to reach the button inside the hole.
May 08, 2009 | D-Link DSL-2320B
mp3 froze completely
press the reset( small hole on back near bottom) with a small paperclip
Mar 01, 2008 | Samsung YP-U3 MP3 Player
1,147 people viewed this tip
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
