Tip & How-To about Televison & Video
Lg tv
My 32'' lg plasma tv won't turn on. i were try it it doesn't happen
Televison & Video Logo
32" TV fell over onto carpeted floor and won't
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
Jul 03, 2011 | Quasar SP-3233 TV
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
I can't turn on my 32 inch plasma tv by LG.A green light flashes twice on the power indicator than turns red.
The flashing indicator is telling you the fault. Give the number of flashes to the LG service department and they can help you with your issue. It will likely need service.
Mar 30, 2010 | LG 42PC3D 42 in. Plasma Television
My LG Flat Screen won't turn on.
power board issue or capacitors on the power board have blown this happens with electronics, service center will be required to replace the board or if you know some one who solders electronics they could do it also. to keep this from happening again buy a ups backup power supply which will condition the power to the tv and other components and save you allot of time and trouble later.
May 26, 2008 | Televison & Video
259 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
