Tip & How-To about Rolex Oyster Perpetual Submariner Date Wrist Watch
How to manage your SUBMARINER's size to fit your wrist
Take of your ROLEX, look on the inside of the bracelet. Near the area where you have the crown, there is a miniature circle, push with your thumb on it with strenght, you will hear a click . You pull your bracelet , it will open, then you look on the sides of the bracelet, and you insert a needle into the little screws on both sides, and then you choose the size you wish for your watch , and then put the circle back and close everything again.
Rolex Oyster Perpetual Submariner Date Wrist Watch Logo
where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    How do you open the latch on a Rolex datejust watch
    If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
    Feb 08, 2010 | Rolex Datejust SS
    How to remove a Rolex jubilee bracelet
    if its a real rolex, take it to a store dont play around with perfection. but the way a rolex bracelet is held on is by spring bars. look at the back of the watch and put a small screw driver in the lots and push down on the spring bar. then start to ease the bracelet out, now dow the same on the other side the end should come out
    Oct 06, 2009 | Rolex Datejust SS
    Oyster Datejust White Gold RX579 Ladies - faux
    Pull the clasp where the Rolex crown is. It may be quite stubborn/stiff.
    Aug 12, 2009 | Rolex Day-Date President 118239 Wristwatch
    how to open a ladies rolex watch band
    how to open rolex wrist band brand new watch
    Oct 03, 2007 | Watches
    1,674 people viewed this tip
    Top Rolex Watches Experts
    Samyfam
    Samyfam
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
