Tip & How-To about Computers & Internet
Optimize your computer in few steps
You can optimize your computer in few steps.
By Removing Junk file:
Go to >> Start >> Run >>(type) Temp hit Enter >> Delete all files and folders.
Go to >> Start >> Run >>(type) %Temp% hit Enter>> Delete all files and folders.
Go to >> Start >> Run >>(type) prefetch hit Enter>> Delete all files and folders.
Go to >> Start >> Run >>(type) cleanmgr hit Enter>> check all box and click OK.
http://www.microsoft.com/atwork/maintenance/speed.aspx
Computers & Internet Logo
slow pc on internet
If your computer has 512 Mb or less RAM then install more RAM.
Dec 09, 2012 | HP Computers & Internet
i can't connect to my Gtalk or any kind of instant chat in my laptop...but at the morning times i could easily connect the Gtalk...the problem is particularly when i use my mobile gprs to browse thru PC
The issue will be due to the internet temp folder will be full. Follow the following steps:
-- Clck Start - Run
-- Run Box Type temp hit Enter
-- New window will open Select all files Delete
-- Again take Run Box Type prefetch hit Enter
-- Again Take Run Box Type %temp% hit Enter
>> Now try to work on Gtalk it will get ready.
May 28, 2011 | Google Talk
It runs really slow and will freeze up. Ran a virus scan and nothing shows up. Ran clean up a defragment and upgraded the memory. nothing works.
YOU CAN PERFORM A FEW MORE STEPS
Manually delete cookie files in Internet Explorer 6 1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer. 2. Click Start, click Run, type inetcpl.cpl, and then press ENTER. 3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files. 4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
RUN DISK CLEANUP
DELETE TEMP FILES
1. Click on Start and then Run.
2. In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
4. To remove individual folders or files, hold down your Ctrl key while left-clicking on each item you want delete. Release the Ctrl key when you're finished.
5. To delete these items, hit your Delete key or choose File and then Delete from the menu.
6. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens.
7. To remove everything inside the Temp folder, choose Edit and then Select All from the menu. 8. Now that all of the files and folders are selected, hit your Delete key or choose File and then Delete from the menu.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted
DELETE PREFETCH
2. In the text box in the Run window, type “Prefetch” and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Prefetch folder , Remove them.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted you can close the window and empty your Recycle Bin, permanently removing the files from your PC.
Note: If you are unable to clean up the Prefetch files follow these steps to remove the Prefetcher from the registry residual
Download Revo Uninstaller: http://www.revouninstaller.com/download/revosetup.exe
AND REMOVE UNWANTED PROGRAMS
DOWNLOAD CCLEANER CCleaner can be downloaded from http://www.ccleaner.com/ AND RUN IT
CREATE A NEW USER ACCOUNT
Jan 31, 2010 | HP Compaq Presario SR1602HM (CPQSR1602HM)...
205 people viewed this tip
David Payne
David Payne
