Tip & How-To about Computers & Internet
Speed up your PC/Laptop ( Boot Faster )
There are few basic ( Manual ) tips to make your PC/laptop run faster.
Follow all the steps given below one after another
First Step :
Click on Start button
Click on Run or under START TYPE HERE type the command "%temp%" without quotes (")
Click OK
A Window will pop-up ( Temporary folder )
Click on Edit from Menu bar and click Select All ( or short cut method to select all the files is Press CRTL + A
Press Shift + Del key to delete the files
Few files may not get deleted so skip those files as you can delete them later
( The files and folder listed in the folder will not harm any data/document/files on your PC as they are just temporary files and can be deleted )
Second Step :
Click on Run or under START TYPE HERE type the command "prefetch" without quotes (")
Click OK
A Window will pop-up ( Prefetch Folder )
Third Step :
Open Internet Explorer
Click on Tools on right side of window and select Internet Options
OR
Click on TOOLS from Menu bar on top and click on Internet Options
Under General TAB - Click on Delete button
Click on Delete Files button and click Yes for the message
Likewise Click on Delete Cookies, Delete History ( if you do not want the list of websites to be displayed when you type www and the website name in address bar ), Click on Delete forms
Click Close
( By doing this you will be able to get rid of any unwanted files and website data that is stored on your pc to make you access internet much faster )
For Mozilla Firefox
Click on TOOLS
Click on Clear Recent History
Select Everything from RECENT TIME
Click Clear Now to clear the temporary files and folder
Fourth Step :
Click on START -> ALL PROGRAMS -> ACCESSORIES -> System Tools
Click on Disk Cleanup
It will display the Local C: drive
Click OK
Wait for sometime
It will analyze the unwanted data to be removed from your pc
Click on to Delete
To Make PC open faster after you login
( there is delay in accessing the PC after you login and see the desktop or till you are able to access your PC files )
Fifth Step :
Click on Run or under START TYPE HERE type the command "msconfig" without quotes (")
Click OK
A Window will popup ( Microsoft Configuration )
Click on STARTUP tab
You will find list of programs with check mark on left side
uncheck any program listed which is related to Update or Software ( for ex. Adobe, Java, MSN, Yahoo, Google talk, etc )
UNCHECK these programs
( Do not uncheck any program you are not sure or is related to your PC like Wireless/router etc )
Click OK
You will get a message to Restart the PC - Click OK to Restart
You will observe change in speed the PC boots
Incase you find any trouble after you have unchecked, follow the same process to open MSCONFIG and put check mark back on the programs that gives you Error
Sixth Step :
If you still find your pc running slow after following all these steps, this is final step to make it work faster
Click on Disk Defragmenter
You will find a Disk Defragmenter window open
click on Defragment and leave the PC idle till it completes the process
Degragmenter will check for any unwanted space created on the hard disk and stores the Files back to their original position in hard disk for quick access.
This is helpful when the PC takes lot of time to open a file or when it makes noise while accessing the hard drive to open/launch software/files
Incase you find trouble to follow any instructions please consult a Technician or Buzz me.
* Please rate these tips if you find them to be helpful with thumbs up and comment
Computers & Internet Logo
get out of hibenate
To help you get out of the hibernate option, just press the power button on the laptop and within few seconds normal desktop screen will appear.
If you have already tried the above step, but the laptop is not coming out from the hibernate option, You need to turn off your laptop once to restart it in normal mode and then change the power settings to turn off hibernate option.
Please follow the steps as given below:
- Click Start, and then type cmd in the Start Search box.
- In the search results list, right-click Command Prompt, and then click Run as Administrator.
- When you are prompted by User Account Control, click Continue.
- At the command prompt, type powercfg.exe /hibernate off, and then press Enter.
- Type exit, and then press Enter to close the Command Prompt window.
GuruAid.com
May 13, 2016 | Sony Computers & Internet
the laptop so slow loding
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Feb 26, 2011 | Fujitsu Computers & Internet
how do i enable cookies so that my gmail would let me sign in
Follow the steps below to clear and enable cookies.
First Step :
Click OK
Second Step :
Click OK
Third Step :
OR
Click Close
For Mozilla Firefox
Click on TOOLS
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 27, 2010 | Microsoft Computers & Internet
how do i make the sylvania netbook faster or load better?
Booting speed is slower due to start up items...Kindly follow the steps mentioned below,
Step1: Click on start and then click on Run.
Step 2: Type msconfig and hit ENTER.
Step 3: Click on Startup tab.
Step 4: Click on Disable all then click on apply and then Click on OK.
Step 5: Your system will be prompted for a reboot. Go ahead and restart it.
Step 6: As soon as the system is backup you would get system configuration utility screen where in you should check "Don't show this message again".
Step 7: You are all set. Try rebooting again and the booting speed will be lot better.
Note: If you want you keep one or two start up items enable which can be done manually. However disabling start up items will not hamper your system in any way it's just that those will not load during boot up. It will still work with out any problem.
Dec 16, 2010 | Sylvania G-Netbook
how to format acer aspire 5315 without disk? its so slow!
Formatting without disc is slow on all laptop brand.
If you want a fast formatting use the installation disc.
Thanks.
Jul 26, 2010 | Acer Aspire 5315 Notebook
1,387 people viewed this tip
David Payne
David Payne
