Tip & How-To about Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 won't flash
Hello Friends,
I have SB-600 Speedlight. it dropped from my hand , from then, it goes to READy state but didn't flash.
Please help me to find a solution for repair it or any tech service with resonable rate .
Thanks
Naser
Nikon Speedlight SB-600 TTL Flash Logo
I have a sb-600 flash. It works fine but it has
Try doing a reset - press the "Mode" and "On/off" buttons together for a few seconds and you go back to factory settings. Sounds like you got into some funky mode, assuming everything else is working ok.
Mar 09, 2010 | Nikon Speedlight SB-600 TTL Flash
nikon speedlight sb 600ttl
You have a bad flash tube or the main baord is damaged .
So if you need any info I can repair this for you
Berrie Smith Camera Repair
770-312-0719
bbmw@bellsouth.net
Jul 29, 2008 | Nikon Speedlight SB-600 TTL Flash
SB-600 will never be on ready
The capacitor may be weak, or there is a problem at the component level that is not allowing the inverter to reach full voltage.
The flash will need shop service.
Jerry G.
Apr 20, 2008 | Nikon Speedlight SB-600 TTL Flash
SB 600 Not resetting...
my sb 600 speedlight won't turn on. Do I need to reset it? It has fresh batteries. Never been dropped
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
1,987 people viewed this tip
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
