Tip & How-To about Computers & Internet
How to prevent from autorun virus??
Actually this virus is activate while autorun execute. So, to prevent from this virus we can disable the autorun feature manually or by using different softwares.
To disable autorun manually follow the steps below..
1.click 'Start' run' enter 'gpedit.msc' and hit enter.
2.on the left pane of the 'group policy' window that opens up, navigate to 'computer configuration'administrative templates'system'.
3.under the 'system' section look for the entry called 'turn off autoplay'. by default, this entry ha its 'state' as 'not configured'.
4. double click 'turn off'.
5. click the ' enabled' radio button on the dialog box that opens up.
6. From the 'Turn off autoplay on:' dropdown list select 'all drives'
7. click 'ok' to save the settings.
If you want to removed this virus by using softwares then i suggest you to download http://download.cnet.com/autorun-virus-remover/3000-2239_4-10862968.html
click the 'download the latest version' link.
Computers & Internet Logo
delete autorun inf virus 4gb
If you have a autorun.inf virus on your memory card/USB stick the anti virus software on your PC may not allow access in order to stop it from spreading.
First you need to disable autorun feature on Windows operating system :
Follow steps in link :
http://www.redmondpie.com/how-to-disable-autorun-autoplay-in-windows-7-and-windows-8/
After disabling the feature you will have access to your memory card/USB stick. The next step is to delete autorun.inf virus file hidden on your memory card/USB stick. But first you need to make the hidden virus file visible.
Follow steps in link to show hidden system files :
http://www.bleepingcomputer.com/tutorials/show-hidden-files-in-windows-7/
Now navigate to your memory card/USB stick you should see the autorun.inf file - DELETE IT.
(If it doesnt allow you to delete it - restart the PC in safe mode by pressing F8 on start up and choosing safe mode and try again)
Back up your files on the memory stick/USB stick to your PC and to make sure the virus is gone from the memory stick/USB format it using your PC.
Dont to forget re-hide your system files to prevent accidental deletion.
Oct 15, 2013 | SanDisk 1GB microSD Memory Card
I just bought it for my son. We have done the initial set-up and we inserted the game disc but it doesn't play?
Hi..
To play a game on PC, you need to pass few bunch marks.
  1. The Game should be Properly installed and registered.
    If the Game is not installed into Computer yet, Please insert the Game Disc. There will a setup file (Installer) to install the game. Many commercial games requires registration before we could play the game.
  2. Your PC must meet the hardware resource requirements for the Game.
    Many Games are Resource intensive. Many need extra hardware resources like a Good Graphics card, Physical Memory (RAM) etc.
    Many games will specify their minimum hardware configuration required to play the game smoothly, on their Disc Packs.
  3. Your Game and Operating System should be Authentic
    If your game disc is not authentic or legal, Operating System will prevent the game from running. The same will do for the Operating Systems also.
    So if you got the Disc illegally, you may need to crack or patch it run.
  4. Auto running Feature should be turned on.
    Many Operating Systems features Auto Running the Disc. That is, if you put the disc on computer, it will run automatically without any user interactions. If your Current Operating System does not have Auto Running Feature (Many new Operating Systems have this feature and its set to On by default) or its set to disabled mode, you can browse the disc and run it manually.
    You can find the executables in the Disc to run the game. Usual Autorun executables have name one of Installer, Autorun, setup.
  5. Your Anti-virus may interrupt the game.
    If you have an anti-virus software, then it may interact with the game's normal play and stop it from playing. This is due to the fact that, many Anti-virus Software mistakenly think the game as a virus and stop it from running.
    So if you have an anti-virus software, please set it to Game Mode or Disabled Mode
Mar 19, 2011 | Computers & Internet
910 people viewed this tip
David Payne
David Payne
