Tip & How-To about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Issue: "Could not start the Remote Procedure Call (RPC) Service. Error
1058" error message when you manually start the Remote Procedure Call service
Resolution :
1 . Restart your computer by
using the Safe Mode startup option. To do this, follow these
steps:
a. Restart your computer, and when the Boot menu
appears, press F8 .
b. Under Windows Advanced Options Menu,
select Safe Mode, and then press ENTER .
c. When the Boot
menu appears again with the words "Safe Mode" displayed at the bottom of the
menu, select the operating system that you want to start, and then
press ENTER.
2 . Click Start, click Run, type regedit, and
then click OK.
3 . In the left pane, locate and
then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Hardware
Profiles\Current\System\CurrentControlSet\Enum\ROOT\LEGACY_RPCSS
4. On the File menu, click Export.
5. In the File name box, type a name for the
registry file.
6. In the Save in list, click
the location where you want to save the registry file, and then click Save.
7. Right-click LEGACY_RPCSS, click Delete, and
in the Confirm Key Delete dialog box, click Yes.
Note Do not delete any
one of the following subkeys that may be found under the ROOT subkey:•
MS_L2TPMINIPORT
• MS_NDISWANIP
• MS_PPPOEMINIPORT
• MS_PPTPMINIPORT
• MS_PSCHEDMP
• MS_PTIMINIPORT
8. Exit Registry Editor.
9.
Restart your computer by using the Restart Windows Normally startup option.
