Tip & How-To about Computers & Internet
Ram Changing
Whenever you change, or add to the ram on your computer make sure your using the same kind thats already in it.
Computers & Internet Logo
how much ram and what kind of ram
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
Apr 07, 2012 | Computers & Internet
I have a Intel(R) Pentium(R) 4 CPU 2.80GHz 2.79GHz processor and would like to add RAM to my computer. It currently has 512MB but im not sure if my computer will allow me to add more. If i can how do i know what model my motherboard is and how to add RAM to it?
There is an app called cpuz (http://www.cpuid.com/softwares/cpu-z.html Download links are on the right side) When you download and run it, the app can tell you what kind of motherboard and ram you currently have. From there you can do a quick google search to see the max allowable amount of ram you can use as well with what kind.
May 04, 2011 | Computers & Internet
hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
162 people viewed this tip
David Payne
David Payne
