Tip & How-To about Computers & Internet
How to clear a cmos password on a Gateway T1625 Laptop
This picture is an actual replacement system board for the Gateway
T-1625 notebook. If you look at the top of the picture you will see the cmos battery location. You will need to remove the hard drive access panel which will allow you to see the battery location. You will need to remove at least 3/4 of the screws on the outside edges of the bottom of the laptop including two screws in the laptop battery location which are of different size than the rest. Set those two aside from the others. You do not need to remove the screw in the center of the laptop with the letter K next to it that is a keyboard release screw. Also remove the two screws located next to the removable wireless network module which is located next to the hard drive. Once you have removed the screws very carefully seperate the laptop casing starting from the middle of the cmos battery location and working you way out to the edges. You do not have to completely take this cover off you only need an 1/2 of an inch of space to work in. I used a hard piece of 1/2 inch plastic to wedge in the center to keep the cover open enough to work in, Once you remove the battery leave it out for a few mins then replace it and put your laptop back together in the reverse order. Your cmos will need to have it's date and time reset when you first turn it back on. Your cmos password will now be removed.
Computers & Internet Logo
where is the cmos battery located in a gateway m255-e laptop
open the top key board then under this key board you located the cmoslb_icon1.png battery and jumper settings..good luck
How to change Gateway M255 PC Notebook cmos battery Where is the mos...
May 14, 2014 | Gateway M255-E Notebook
CMOS battery gateway t-1625
Remove the keyboard and the media button panel.
Remove all the screws from the underside of the laptop.
Remove the access panels.
Remove the hard drive.
There are three screws that holds the chassis together here (inside the hard drive bay). You won't be able to completely open the chassis but now you can use a flat blade (I used a small flat head screw driver) and pry the top and bottom pieces apart.
As I mentioned, you won't be able to completely take the two chassis pieces apart but you will now have enough clearance to access the CMOS battery to the right of the headphone jack (looking at the bottom).
I used a small flat head to pop the battery out. I then used long tweezers to place the new 1220 battery on the battery tray and reached around from the hard drive bay and popped it in with my index finger.
Put everything back together in the order you took it apart.
Apr 05, 2012 | Gateway T-1625 Notebook
gateway m-1625 laptop hard drive replacement
did you create a boot partition and format NTFS?
Nov 06, 2009 | Gateway M-1625 Notebook
Mouse is not accepted by the system.
it is likely that the mouse is not compatible with Vista
Jul 15, 2009 | Gateway T-1625 Notebook
Gateway T-1625 - System only recognizes parts of the Memory
I bet that the video card on the motherboard is using some of your main memory. As for the cpu driver I would go to the device manager and revert back to last driver or use a utillity like Uniblue's DriverScaner.
Jun 05, 2009 | Gateway T-1625 Notebook
203 people viewed this tip
David Payne
David Payne
