Tip & How-To about Cameras
Recharging your Vivtar 8025 camera
Did you know even if you have an USB extention on your computer that you can still recharge your Vivtar 8025 camera? Yes, it is true. I tried it and it worked. Now, the battery is full and movies and pics are beingmade into memories. This will work only if yoru computer puts out alot of power. This won't work on all computers. But, if your the adventuresome type, give it a try.
Cameras Logo
the sound on my vivtar isnt working
The 8025 was designed primarily as a still camera, with some video features grafted on. As such, it captures images not sounds. You can add a soundtrack using video editing software on a computer, but the camera does not record any sound.
Apr 12, 2014 | Vivitar ViviCam 8025 Digital Camera
How do I recharge my battery in my 8025 camera.? Thanks, Flo
There are two ways you can recharge the 8025's battery. One is to use the supplied charger. Remove the battery from the camera, put it into the charger, and plug the charger into a wall outlet. The second is to connect the camera to a powered USB port using the supplied cable. Be aware that not all computer USB ports put out sufficient current to charge batteries.
Jan 30, 2011 | Vivitar ViviCam 8025 Digital Camera
flash problem
There's a switch on the side of the camera where the USB cable plugs in. Flip that up or down (depending on where it's at when you look) and that should fix the issue.
Dec 27, 2009 | Vivitar ViviCam 8025 Digital Camera
i dont have any sound for my Vivitar 8025. do thic
i have vivtar 8025, it seems that it has no mic, so no sound. that's bad for such camira has a fine quality picture. i am going to turn it back.
Sep 29, 2009 | Vivitar ViviCam 8025 Digital Camera
211 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
