Tip & How-To about Computers & Internet
How to Connect a Mac Laptop to a Cell Phone Modem
  • 1 Connect the USB data cable to your wireless phone. This data cable is going to plug into the power port you use to charge the device. Plug the other end of the cable into an available USB port on the computer.
  • 2 Click on the blue Apple icon in the upper-left hand corner. From the drop-down menu, select "System Preferences."
  • 3 Click "Network" in "System Preferences." The Macbook is going to scan your system to see what networks are available to you. Once the Macbook has detected your wireless phone you are going to be greeted with a pop-up window stating a new port has been detected.
  • 4 Download and install the wireless modem driver for your phone. There is a link in "Resources" that has a series of different drivers. If you do not see one, you can go to your wireless phone's manufacturer's website and download the drivers directly from the site.
  • 5 Open the Finder and type "Library" in the search box. Open the Library folder, followed by "Modem Scripts." Click and drag the driver you downloaded into this window.
  • 6 Return back to "Network" in "System Preferences." Click your phone as the default modem.
  • 7 Click "PPP" and type in the account name, password and telephone number of your Internet Service Provider (this is given to you when you first create your Internet account).
  • 8 Accept the changes and you are free to start surfing the Web with your wireless phone as the modem.
  • Posted by on
    Computers & Internet Logo
    How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
    first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
    If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
    Also, some Cable adapters are On the Go wired, and may not work properly.
    It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
    Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
    What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about the port being over powered/shut down. Is the Sansa connector usable with the Phillips device? Thank You
    INSUFFICIENT POWER - USB PORT
    If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
    Apr 10, 2013 | Audio Players & Recorders
    compatible charging cables for phillips go gear hdd1630/17
    Apr 10, 2013 | Philips HDD1630 MP3 Player
    How do I pair a RocketScience Tracer bluetooth?
      • 1How to Pair a Bluetooth Device With an iPhone On the iPhone, click on the "Settings" icon. It looks like a gear. Then press on the "General" button. Select "Bluetooth" and then "Turn Bluetooth On." The phone is now ready to be connected to the Bluetooth device.
      • 2 Connect the iPhone Bluetooth travel cable that comes with the iPhone-approved Bluetooth device into the USB 2.0 port on the computer. Do not plug it into the USB port on the keyboard.
      • 3 Connect the iPhone to the other end of the cable. The cable goes into the data connection slot on the bottom of the iPhone. There is another slot on the top of the cable into which the Bluetooth device should be plugged in.
      • 4 Wait while the computer loads to recognize there is something plugged into it. Either a screen will pop up or an icon will appear on the desktop to let you know that the computer is recognizing there is a iPhone plugged into it.
      • 5 Let the Bluetooth device charge with the iPhone for about one hour. You can tell when the device is fully charged by viewing the status light on the device. It will be an amber color until it charges completely. Once the charge completes, it will turn green.
      • 6 Remove the Bluetooth device and the iPhone from the cable that is plugged into the computer's USB port. Push the button on the top of the Bluetooth device. This allows the calls to now go through the Bluetooth device instead of straight to the iPhone.
    Jan 02, 2012 | Apple iPhone 3G
    137 people viewed this tip
    David Payne
    David Payne
