Tip & How-To about Computers & Internet
Create Desktop Shutdown/Lock/Restart/Hibernate Shortcut Icons In Vista
1. Right click an empty area of your Desktop
2. Select New>> Shortcut
3. In the text box titled: "Type the location of the item:" Enter the Command for the particular shortcut you would like to create. I've listed all of the commands below that activate their respective shortcut:
Hibernate rundll32.exe PowrProf.dll,SetSuspendState
Lock Rundll32.exe User32.dll,LockWorkStation
Restart Shutdown.exe -r -t 00
Shutdown Shutdown.exe -s -t 00
Sleep rundll32.exe powrprof.dll,SetSuspendState Sleep
4. Once you've entered the command, click "Next"
5. Vista will now ask you what you would like to name your shortcut. I've always just given it the name of its function (EG: Shutdown or Shutdown System).
6. Once you have named you shortcut, click "Finish". Your new shortcut will now reside on your Desktop. Simply double click the icon to activate the command.
Note: If you do not like the look of the "default" icon that Vista has given it, you can change the icon to a different one. Here's how:
1. Right click the shortcut icon
2. Select Properties
3. The shortcut properties window will now be displayed. Click the "Change Icon" button.
4. The "Change Icon" window will now appear. Here, you can select from the many available system icons. Click the icon that you would like to use as your shortcut icon and then click OK.
Your Desktop shortcut icon will now revert to the selected system icon.
That's it! Have fun!
Computers & Internet Logo
volume control
Yes,you can create a Master Volume Shortcut and also assign a Shortcut Key.
Right click on a empty area on desktop, and click on New and Shortcut.
Paste the following in to the location of the item area:-
%windir%\System32\SndVol.exe -f 49825268
Click Next button and give a name to the Shortcut and click Finish.
Now You right click on it and select Properties.
Click Shortcut tab.
Assign your desired shortcut key like F8 or F9 in the Shortcut Key area.
Click OK/Apply
Is There Keyboard Shortcut For Volume Control
Mar 13, 2015 | Computers & Internet
Datamngr Coordinator has encountered a problem and needs to close
Sound like you might need .NET installed, you can make a short cut on Win 7 desktop and check application on the list box. Here is a tip to make that easy short cut link on your desktop.
  • Right Click on an empty area of your Desktop
  • Select >New > Shortcut
  • In the "Type the location of the item, type:
  • C:\Windows\System32\eventvwr.exe
  • Click on Next
  • Give a name to the shortcut
  • Validate with OK
Dec 05, 2013 | Microsoft XP Computers & Internet
147 people viewed this tip
David Payne
David Payne
