Tip & How-To about Computers & Internet
How to delete temp files to speed up your machine?
Hello Friends,
I would like to share some steps to speed up your machine, which sometimes becomes slow because of temp files.
1) Make sure that you are able to login on Machine.
2) Go to start > Run (Ctrl +R)
3) Type "Cmd" then press "Enter"
4) Now make sure in command prompt there should be c:\ only. If there is any other text written (i.e. c:\documents and settings\) then Just type CD\ and press "Enter". Now you will get the C:\
5) type "Del *.tmp /s" and press "Enter". It will start deleting all the temp files. It can take time depends on your HDD capacity. You can stop it in between by pression "Ctrl +C".
6) Once its completed, you can Type "Exit". Now the CMD window will be closed.
7) Again go to Start > Run and type "Prefetch" then Press "Enter". One box will be open where you can see lots of files. Just Select all by pressing (Ctrl +A) and Delete them.
Once its deleted. Restart your PC you will face enhacement of your machine speed.
This article applies of all windows version.
With regards
FIXYA team
Computers & Internet Logo
my internet speed is very low i have broadband connection and anti virus then my internet speed why very low plz tell me
You can delete all the files from below location. Dont worry this files are waste space consumption. You are not going to loose you data by deleting them.
What is the internet speed you have.
To increase the speed.
Click Start - run - temp click OK
Delete all files.
Click Start - run - prefetch click OK
Delete all files.
Click Start - run - %temp% click OK
Delete all files
Disable your antivirus program and see the speed.
Make sure you remember you passwords on the internet. Like your bank and emails password. Else dont try the below steps.
Open internet explorer. Click Tools - options - Go to Advanced Tab Click Reset, which will be at the very bottom.
This should fix your issue. If there is any problem on the system. Else contact your internet provider.
Mar 28, 2011 | Computers & Internet
internet download slow?
the download speed depends on the seeders(from who you download) check this first
Jan 27, 2010 | EPoX EP-8KRA2+ Motherboard
My processor has become slow and the fan sometimes works, sometimes it doesn't..makes a noise also...thanks
Replace the fan as soon as possible. The processor is running slow because it is overheating and the motherboard is cutting its speed to prevent the processor from burning up. Many motherboards have this throttling built in, they first try to make the fan go faster, if that does not work the board drops the speed to try to reduce the temp. be sure to check the fan in the power supply too, that one can also make a lot of noise if it is dirty.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 22, 2009 | Computers & Internet
HP PSC 1410 All-In-One printer speed is slow
Hello Sir,
I would like to provide you few workaround steps, you may try to improve the printing speed on the computer.
Delete all the Temporary files:
For Windows XP:
(1) Click Start >> In the Run window, type "%temp%" which opens temporary files folder.
(2) Delete all the files that are listed over there.
If Windows Vista:
(1) Click Start >> Programs >> Accessories >> In the Run window, type "%temp%" and press enter.
(2) Delete all the files listed under temporary files folder.
Another Workaround:
(1) Click Start >> Printer and Faxes.
(2) Right click on the Printer icon which is set as default and select properties.
(3) Click on Advance Tab.
(4) put a check mark on "Print Directly to printer" option.
(5) Click Apply and Ok.
Hope this solution would be helpful in resolving the issue that you are experiencing.
With Regards,
Ashesburn..
Feb 24, 2008 | HP PSC 1410 All-In-One InkJet Printer
191 people viewed this tip
David Payne
David Payne
