Tip & How-To about Computers & Internet
Add the "Run" command back to the Start menu In Windows Vista
Right click an open area of the Taskbar2. Select Properties
Select the Start Menu tab4. Tick the Start menu entry and click the "Customize" button to the right.
Scroll down the list until you find the "Run command" entry.6. Place a checkmark in the "Run command" checkbox.7. Click OK.
The Run command should now appear in the Start Menu.
Computers & Internet Logo
how i can download afree cmd.exe
cmd.exe, also known as the command prompt, is the command-line interpreter on Windows PCs. You do not need to download it it is already a part of Win XP.
All you need to do is click on Start, select Run and in the dialog box that opens type "cmd" and press Enter. A command prompt window will open.
Jan 10, 2011 | Microsoft Windows XP Professional
When I hit the bottom left hand MS Icon to bring up list of programs to launch the list on the right hand black column list my main file areas such as 'Pictures' and used to list 'Documents' but for some reason this entry is now missing how can I restore it? The My Documents folder is on a second hardrive 'E'
Click the start menu button so it opens up the menu where the documents used to be, then right click on the start menu. Click properties a pop up should open up saying taskbar and start menu properties. Click the start menu tab, if your not already on it. Then click the customize button. It should open up another pop up saying customize start menu. Then click use default settings button near the bottom of the pop up or you can click the check box under the documents that says display as a link. After doing all that click ok on the pop up it should close. Then click apply and ok on the other pop up it should then close that. Then click the start button and it should show your documents. If you need more help comment and ill try again. If i helped please leave me a rating.
Jan 14, 2010 | Microsoft Windows Vista Ultimate Edition
Dear Friends, I lost in START menu HELP AND SUPPORT option for my Windows XP Professional. What should I do? Kindest regards, Janusz Melbourne (Australia)
right click on your Taskbar and select Properties, and you will see a box as below:
Click at Start Menu as above, then click Customize as below,
In Customize Start Menu, tick Help and Support and click OK.
Jul 31, 2008 | Computers & Internet
pre set mail button
step1 :ensure that hotmail is default email program by these steps ...look at settings for...right click while hover over blank area of start menu then select properties then select from start menu then select the GENERAL tab and ensure that Hotmail is your default and then select to view it on start menu and hit OK. Now go back to start menu and right click over your new hotmail icon and drag it onto the desktop. it will now be a desktop shortcut.
Sep 20, 2007 | Acer Aspire 5100 Notebook
138 people viewed this tip
David Payne
David Payne
