Tip & How-To about Vacuums
Bissel Carpet Cleaner Won't Dispense Water
"My Bissel carpet cleaner has little to no spray action".
This is a common problem and here are some Trouble Shooting solutions. If your machine is only dispensing a little bit of water, or none at all, then:
1. The bladder may be empty- Turn power off, remove tank and refill.
2. The lent screen may be clogged- Clean out the lent screen.
3. Tank-In-Tank may not be seated properly- Turn power off; remove tank and reseat tank.
4. The pump belt may be broken- If so, replace with a new one. The belt can usually be accessed through a belt access door on the top-side of your machine.
Here is a Link that will help in your search for the right belt:
vacuumcleanershop.com/
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Carpet Cleaning, Rug, Steamer, & Stains
Vacuums Logo
new bex bissel wont release water onto carpet
Hey Margart! I understand how frustrating it is to have no spray when trying to use a machine.
We have a terrific list of FAQ's on our website to assist you. Here's a quick link: http://www.bissell.com/faqs/?cid=ccsocial
Feb 09, 2013 | Vacuums
how bad is it not to use bissel solutions with bissel machine
The machine does not know what brand cleaners you are using, at issue is foaming, otherwise any cleaner should be okay. This is presuming you are using carpet cleaning solutions.....
Jun 11, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Little Green Spray Motor
Motor was seized. Probably from lack of use combined with the moisture involved with such a device. I loosened the motor with a pliers, gave it a small shot of wd-40, and off we go. Works fine.
Mar 09, 2008 | Bissell Vacuums
509 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
