Tip & How-To about Computers & Internet
How to by pass acer bios password
Acer laptop has a special bios sequence that can be so tricky and very confusing but I can
show how to do it in few minutes. These steps are simple and picture illustrated.
You can handle or solve bios password problems by either flashing the bios but this can
be done by a professional which is very risky and can damage the laptop,
Or by replacing certain security chip or resetting the one in the board, this will be costly
and also risky.
Or by contracting the manufacturers. Well, good luck!
Above all am going to show you the simplest way to bypass it. The truth is that the bios
password will prevent you from setting the boot order because the default boot order is
either ide or USB devices.
Don't worry, follow these steps:
1. Switch the laptop, and remove the hard disk from the back of the laptop.
2. You need external USB mass storage drive that you will use to connect it to
another computer.
3. You also need third party software like epm partition magic (click here to
download it). Install this software in the other computer before you plug in the
USB mass storage device.
4. then open the software select on the hdd, then press delete and after that click
apply, the system may require to boot(allow it to do so). When this is done, if
open the epm again, your hdd will show in the window (UNALLOCATED). Don
creates partition, just disconnect the hdd and insert it back to your Acer laptop.
5. Put your bootable cd like window xp or vista. Power on the laptop, it will
automatically enter to boot setup.
6. After the setup and you still want remove the password, you will use bios debug
software. Good luck.
By Divine O Fabian. www.laptopmasterpassword.net
Computers & Internet Logo
acer 5315-2698 bios backdoor password
You didn't mention what BIOS you have..(re: pheonix or ami or Award) so you can try "BIOS" or "CMOS" or "ACER" or "PASSWORD" or you can remove the CMOS batttery for a few minutes
Dec 29, 2010 | Acer Aspire 5315 Notebook
my acer notebook is locked form bios ,may be ask for root password,i m not able to do anything,how can i break the bios password??
and also risky.
another computer.
Sep 28, 2010 | Acer Aspire One PC Notebook
Acer Laptop random shutdown
i think the problem there is the laptop's overclocking too excessive try resetting bios or in their words set it to default
Nov 18, 2008 | Computers & Internet
bios password
Yes this laptop is a bit tricky...
You cannot just remove the cmos battery...
This s what you can try
to clear the CMOS, the jumper is below the RAM bridged with a screw driver.
2 shiny dots on the board below the RAM
hope it helps
KG
Oct 15, 2008 | Acer Aspire 3690-2196 Notebook
217 people viewed this tip
David Payne
David Payne
