Tip & How-To about Computers & Internet
Surge Protection
Here is a few tips to look for in a good surge protector:
1. Response time should be less than 1 nanosecond.
2. Energy absorption/dissipation should be at a rating of 600 joules or more.
3. Clamping voltage should be 330 V to 400 V. Generally, a clamping voltage more than 400 V is too high.
4. Get one with a an indicator light that tells you if the protection components are functioning. All MOVs (Metal oxide varistors (MOV) are semiconductors that protect electronic components and systems from transient voltages) will burn out after repeated power surges, but the protector will still function as a power strip. Without an indicator light, you have no way of knowing if your protector is still functioning properly.
5. Get one that has self test function. A button you push to test it.
Computers & Internet Logo
can I bypass energy smart panel on whirlpool water heater
Yes, you can convert to ordinary electric water heater by removing the electronic thermostat and lower thermistor, and installing generic mechanical thermostats:
http://waterheatertimer.org/How-to-convert-energy-smart-water-heater-to-ordinary-water-heater.html
The front panel control can also be unplugged, and the unit will work fine on the electronic thermostat.
Don't forget... all these modern electronic water heaters are susceptible to surge. Nearby lightning strike can blow them out. Install type 1 or type 2 surge protection in main breaker panel
http://waterheatertimer.org/How-to-wire-Whole-house-surge-protector.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 18, 2015 | Whirlpool Water Heaters
110v surge protector that conserves power for freezer
A surge protector for a freezer is a good idea. To conserve energy? On paper it looks good but seriously only real savings are on bigger equipment.
Apr 25, 2014 | True 19 cu. ft. / 538 liter Commercial...
What's the difference between a surge and a spike in voltage?
A spike is an increase in voltage for 1-2 nanoseconds.
A surge is the increase lasts 3+ nanoseconds.
Feb 05, 2014 | Electronics - Others
my wii stopped working. the light is off. i tried unplugging and plugging everything back in twice. it was plugged into a surge protector, but the electricity did go out in my house today.
MysticMynstr: I know you already figured this out. But, you posted the solution as a comment and it will be easily missed. Also, the problem still shows with an unconfirmed solution.
Unplug the power adapter at both ends (at the console and especially at the power outlet). Give the capacitors at least a minute (perhaps longer) to completely dissipate residual energy. Make absolutely sure to wait long enough during power disconnection. Then, hook it back up and it should be good to go.
If the power light does not come back on, even after wait several minutes. The power adapter will likely need to be replaced. Any electronics shop will be able to test the power adapter first to be sure it is the problem.
I would give credit to someone else for this super simple solution. But, it's all over the internet.
May 16, 2011 | Nintendo Wii Console
1,166 people viewed this tip
David Payne
David Payne
