Tip & How-To about Lands Phones
HOW DO I TURN THE KEY TONE ON TO MY PANASONIC PHONE
I don't have key tones to my phone
Lands Phones Logo
I DONT LIKE RING TONE
Hi
If u don;t like the ring tone then change the tone or u don;t want ring tone the put your mobile in silent mode.
May 28, 2011 | Cell Phones
I just want to stop the keys making a noise when I text
Hi there!
If you're hearing a noise or a tone whenever you text then ill be advising you to check the tone settings on your phone.It might be that the KEYPAD TONE in your phone is enabled.
If you want to adjust the volume of youe keypad tone then you can just go to SETTINGS.And after that please go to TONES/TONE SETTINGS and kindly look for KEYPAD TONE.You can lower down or turn off the volume of the keypad tone on that option. If you have another kind of phone then you can try looking for small buttons on the side of the phone. You can press the "Down" button to lower the key volume. Please press it repeatedly to continue lowering the volume. Press "Up" button if you decide to turn the key tones back on.
THANKS graham569!
Apr 20, 2011 | Cell Phones
my office phone have a problem when customer call always complain i dont pick the phone but the problem is i dont hear the ringing tone please help
You can find detailed information about your phone from the given link below.
Panasonic KX-T7730
Check the steps below for "Does not Ring" solution.
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | Panasonic KX-T7730 Corded Phone
swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
CHANGING THE RINGTONE
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Press STORE
Press STORE
Mar 20, 2008 | Panasonic KX-T7730 Corded Phone
397 people viewed this tip
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
