Tip & How-To about Measuring Tools & Sensors
Anything Go By Logic... Wen it Time To Fix Something., You got to Be Ready Mentaly and Physicly, That Why It Very Important To Observe Anything You Do. Security First,,,, Always Keep Your Shop Clean Make Sure All The Tools Are In Place and Clean... Never Let Someone Use Your Tools Or Instruments without experience... Drink & Food also Smoking on the Shop is not a good Idea.. samething for Cellular... Cellular Can Cause serious accident.. The Main Idea is Stay Focus anywhere and anything You do on the shop.... First Thing To Do Before Starting Anything Make Sure You Got All The Specific Tools before you start fixing or built something... Alway Mark On a Peace off Paper all the Part You need.. before you fix or built Something., Always Get All The Information You Need On The Product You Fix First.. Exemple Compagny Brand, Quality, Durability, Price List. Service & Warranty.
Measuring Tools & Sensors Logo
have an error message on screen sayng NO HDD???
The system does give this message when the logic board can't access the Hard Disk.
Can be anything, from a complete over filled HD till a defect controller or just a corrupted first sector. Check what the user manual says about initialise the hard disk. If that won't help, consult a tech close to you. Btw. after an initialise or format you will have lost everything you recorded till now. So if something important is on the disk, ask a tech to get out the drive and recover the important stuff. This could cost you.
Mar 30, 2015 | GW Security Professional 4 Channel 1t Hdd...
Wen car is cold engine noisy ok wen hot /ve commodore
you have to observe oil pressure of an engine oil when it is cold ..it might be lack of oil pressure when the the engine is cold
Feb 09, 2015 | Cars & Trucks
color on tv
If this happens to all the input sources, the main logic board is fired. If this happens to only one input source, only that input source circuit is fired.
It is costly to replace the main logic board. And then there are other components ready to die out soon.
Your set is at least 5 to 6 year old. Have you replace the lamp yet? It is rated for 10,000 hours. Yes, it will fail in about 10,000. Off brand replacement is cheaply made, can cost problem. (mine did). The nut holding the wire to the lamp was loose.
Time for a new TV. A new 46-47 inch LCD is less than a grand.
Apr 01, 2010 | Panasonic PT-50DL54 50" Rear Projection...
wen i log into my id on orkut a blank blue page is displayed
dont worry.Its a bug in orkut only.It wil be fixed soon.Till then use "m.orkut.com" its the mobile version.Although you wot get all features.Bt stil something is better than nothing.Right ? all the best
Jun 07, 2009 | Computers & Internet
SLIGHT GREEN TINT TO PICTURE
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Feb 26, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
1,203 people viewed this tip
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
