Tip & How-To about Cell Phones
Rim BlackBerry Change Signal from Bars to Numbers
First you need to be on the home screen when you are there press and hold
ALT then type N then M then L then L
Now you bar signal should be changed to numbers
Cell Phones Logo
Blackberry 7290 unlock proceedures
Hello.
I think I see your problem.
The 'mepd' must be uppercase. Hold the shift key down while typing in the MEPD.
Once you get into the area that shows what limitations are active or disabled, then you must use the Alt. Option key on the fare left third row of keys down. Holding the Alt. Options key, type MEP then release the Alt. Option key and press 2.
You should now be prompted to enter the unlock code. If not, start from where you had the last correct results. Also, If it will not work, back all the way out to the memo icon and try the keys you need to type to insure all of the keys are working and you are not fighting a temperamental key switch.
Good luck in your quest.
If you still need more help, just ask.
Oct 17, 2008 | RIM BlackBerry 7290
108 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
