Tip & How-To about Computers & Internet
Laptop screen resolution problem and solution
Laptop Screen Resolution Problems and solution
By hamack4real, fixya Contributor I want to do this! What's This? jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); });
Laptop screen resolution problems can vary for a variety of reasons. The most common types of problems generally involve some sort of hardware or software issue that causes the display to not work correctly. Correcting a laptop screen resolution problem can be done by making changes to hardware or software settings used by the computer.
    Symptoms
  1. There can be many symptoms to a display problem. Symptoms can include a screen that appears dim or one that is totally black. Other symptoms include odd colors or blotches that appear on the display as well as oversized icons on the desktop. Symptoms can also include icons that are the wrong size on the desktop.
  2. Causes
  3. There can be many causes that can result in different issues affecting the display. Common causes include damage or loose parts. Damage can result when the laptop is dropped or has something fall on top if it. Hinges that are loose are going to cause a problem because the display will not stay in an upright position. Other causes include a bad video driver or an improperly set resolution.
  4. Diagnose
  5. A screen resolution problem will need to be diagnosed to determine what actions to take to resolve the problem. Check the laptop for any loose or broken parts that might need to be repaired. Once that is done, run a test of the video display. Use the video display troubleshooter for Windows XP systems, the help and how-to for Windows Vista systems and the troubleshooting guide for Apple computers.
  6. Solutions
  7. Changing the resolution of the display can be done to fix some types of screen resolution problems. Changing the resolution can fix display problems with some programs as well as websites that have embedded video. Refer to the laptop manual for instructions to access the display settings to change the resolution setting. Updating the video driver might also help to resolve some known issues by the vendor.
  8. Brightness
  9. A dim screen can be corrected by adjusting the brightness of the display. Adjusting the brightness can be done on the keyboard as well as from the display properties. Press the FN key on the keyboard and use the right arrow key to increase the brightness of the display. The brightness settings can also be found as an option in the display settings. Keep in mind a laptop will dim the screen to conserve battery
Computers & Internet Logo
Hi, I have this problem with my dell inspiron N 4010 laptop. Whenever i want to play games on my laptop it either crashes down or after the game is over i get a "Optimum resolution error message". how do i deal with this? please help. I am not a technical person at all so unable to understand the issue.
The LCD monitors and laptop monitors nowadays have a 'optimum resolution'. The monitor likes to work at a pre-defined resolution.
Games play at a resolution previously set. Usually this differs from the optimum resolution of a LCD/LED screen. Then this error message will appear.
However, crashing of the computer might happen due to other reasons.
*Defective RAM *Not-so-good VGA *Viruses
You have to make sure the above problems are not the reason for crashes.
Also try playing somewhat older games. If the problem occurs due to your VGA not supporting the new games, older games will work fine.
Try these suggestions and let us know.
Good luck, and thanks for using FixYa!
Oct 30, 2011 | Samsung Digimax 4010 Digital Camera
when i installed windows 7 in my laptop.my screen resolution decreases,so what can i do to increase my screen resolution?
first right click at desktop background, then click personalize, then click display setting, after that chose resolution that you want, for example 1366X768 then click ok
i hope this helpfull, please rate very helpfull if you think this helpfull, and don't rate if you think not helpfull
thanks for using fixya
Jan 20, 2011 | Computers & Internet
341 people viewed this tip
David Payne
David Payne
