Tip & How-To about Audio Players & Recorders
Using Proper Speaker Polarity
Sound system speakers have standard polarity which is indicated either with a "+" or a "-", or with Red and Black colors near the speaker terminals. This same polarity marking is also found on the sound system amplifier section. Most speaker cable has a polarity indication; either color coded, or a physical difference in the wires. Reversed polarity results an obvious decrease in bass, and a hollow sound in the mid range frequencies. If your speaker cable has no obvious polarity indication, you can check the polarity as follows; connect a 9V battery to each speaker cable for no more than about a second; long enough to see the woofer cone move. When the + battery terminal is connected to the + speaker lead, the woofer cone will move out. When you have this situation, label the positive speaker lead, either with tape, or by tying that wire in a simple knot. Make sure both cables are checked.
What is the error code W-1 Phase mean and how do I correct it?
"W-1 Phase" error, when running the YPAO, means that one or more of the speakers in your home theater set up is out of phase. This happens when the + and - wires are not consistent throughout all of the speaker connections (red and black terminals). Make sure your red/copper color wire is connected to the "red" speaker terminals , and the silver color wire is connected to the "black" speaker terminals. This error can also happen even if all of the speaker cables are connected correctly but the acoustics of the room are creating the out of phase sound the microphone is picking-up.
Oct 27, 2014 | Yamaha Audio Players & Recorders
PROTECT AND PUSH POWER IN THE VISOR.NO SOUND,NO NOTHING WHAT CAN I DO?
This happens when the speaker wires are not connected properly. Remove all speaker wires from the back of the unit, and re - install them, in the correct order and with the correct polarity (white stripe on wire to red terminal, no stripe to black terminal)
Hope this helps.
Jan 24, 2011 | Sony DHC-MDX10 Shelf System
which terminal is positive and negative on Pioneer car speakers. thnaks Shane
Look closely at the terminal of the speaker, the size is different from positive and negative.
The bigger terminal should be positive( + ) with a stamp mark on the terminal itself.
The small one should be the negative ( - ).
Hope that helps you!
Thanks for using Fixya!
Dec 11, 2010 | Pioneer TS-A6955 Coaxial Car Speaker
Internal wiring schematic for a JBL 4311 WX-A
the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
Feb 16, 2010 | Audio Players & Recorders
Replacing the Stereo in an 1995 Audi A6 Quattro....
I assume this is an aftermarket radio and you don't know the connections?
Normally, the red is + and the black -. A yellow wire usually is a feed to a power amp to turn it on when the radio goes on.
On the speaker side, you should have paired up wires like:
Yellow solid and yellow w/black stripe
Brown solid and brown with black stripe
Green soild and green with black stripe... you get the idea. The solid color wire is the positive and the balck striped match is the negative.
There should be 8 speaker wires altogether to give you L/R fron and L/R rear.
If you don't know which terminal is positive and negative on your speakers, try this;
Take a 1-1/2 volt AA battery and connect it to a speaker momentarily ( I do mean momentarily or you'll blow it). If the speaker cone moves out away from the magnet then the terminals match the polarity of the battery - and +.
If the cone moves towards the magnet the polarity is reversed. It is important you connect the speaker phasing (polarity) correctly other wise you will get poor bass output.
Whatever you do, do not ground any speaker wires!!!!
Aug 22, 2009 | 1995 Audi A6
2,333 people viewed this tip
 Grubhead
Grubhead
