Tip & How-To about Sony Playstation 3 (PS3) Console
How to jailbreak your ps3 (backup and play homebrew games)
How to jailbreak PS3(PlayStation 3)? chips available at www.ndsireland.webs.com
Follow the complete step by step guide posted below to jailbreak your PlayStation 3 to enable you to create backups of original discs.
Pre-requisites are as follows:
* Any (FAT or SLIM) PlayStation 3 Console running firmware 3.41 or above.
* PS Jailbreak USB Modchip.
* An external USB drive formatted to FAT32 with the "Backup Manager" file on it which you can download from here.
* Original disc of any PS3 game which you want to backup.
Step 1: Power off your console and make sure that there isn't any disc in the Blu-ray drive.
For the SLIM Model: Remove the power chord before plugging in the USB.
For the FAT model: Turn off the power switch found at the backside of the console.
Step 2: Now insert the USB based PS Jailbreak Modchip to any USB port of your choice on the console. Once the USB is in place, Power ON the console and immediately press the "Eject" button. There should now be two LEDs turned-on on the USB as the console is loading.
If the LED light on the USB turns green, you are good to go as the PS Jailbreak has been successfully loaded.
If the LED turns red, then it means that the PS Jailbreak Modchip didn't load successfully. This usually happens when the Power and Eject button sequence wasn't performed properly. Start from Step 1 again if you end up having the red light.
Step 3: Once the console has finished booting up with the PS Jailbreak Modchip, plug-in the external USB storage device which has the "Backup Manager" setup to the console's USB port.
Step 4: Now navigate to the "Game Menu" and select the option "Install Package Files" and then select "manager.pkg" file. This will basically install the "Backup Manager" application that you download earlier to your hard drive.
Step 5: When the "manager.pkg" file is done loading, scroll all the way down in the "Game Menu" and there you should see a new application called "Backup Manager", run it.
Step 6: Now we're in the Backup Manager app. Insert the game in the console's optical drive which you want to backup. Press "O" and you will be asked where to make the backup, on the internal HDD or the external storage source connected via USB. This process is further elaborated by the following screenshots.
Step 7: In order to play a game via the backup you just made, insert any original game disc into your console (To emulate the loading process), run "Backup Manager" in the "Game Menu". Press "X" to play the selected backup game.
Step 8: Now you will be taken back to the main menu. In the "Game Menu" you will see the game which you have backed up. Now you can select the game, and run it without having the disc in the console's drive.
Oh and you must make sure that the PS Jailbreak USB Modchip is connected to your console at all the times when you are playing the games via backups.
Disclaimer: This guide is for educational purposes only. I'm not responsible for any loss of important data or malfunctioning of your Game Console.
Sony Playstation 3 (PS3) Console Logo
When I put in a movie or game the Playstation 3 will freeze up or give random snow bars. Is there a way to fix this?
Hello
your PS3 is freezing simply because your console is affected by heat, so you have to cool it down.
If the freezing continues even after cooling down, you can follow the steps below:
To stop the PS3 from Freezing, you could begin by putting off your console and wait for 20 minutes. After that, put it back on.
Check if there's any loose cables. If there is, put them back in.
If the freezing continues after taking the above step, you can follow the link below as a guide on how to fix the problem.
http://www.squidoo.com/PS3-Repair-Guide
Good luck
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
my playstation 3 just started freezing up. It comes on and tries to find network but then just sits there. I can move the cursor over put as soon as i click on something it stops again and will not turn off unless i hold down the off button It is then new 250 gig
Hello
Good luck
My playstation keeps freezing while im on any game, it works for like 10 minutes and then it will freeze. it also takes a long time to turn off what should i do?
Hello
Good luck
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
my playstation 3 keeps freezing up on me,what should i do?
Hello
Good luck
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
My ps3 frezzes after a few seconds of being on. WHat happend?
Hello
Good luck.
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
873 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
