Tip for Elite 45986 Front Load Washer
F05 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washing...
posted on May 28, 2008
jsrock516
jsrock516
Rank: Guru
Rating: 96%, 7533 votes
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F05” Error Code.
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope this information if found to be helpful. If you have questions, or need assistance locating parts, please click on the following link and use the “ASK ME” feature for a quicker response.
http://www.fixya.com/users/jsrock516
Very Helpful
Was this helpful?
Yes
No
6 people thought this was helpful
Comments
- Nov 16, 2009
THANK YOU - I removed the bottom panel and the plug had come loose from the harness. 2 seconds to plug it in and works just as before
Much appreciated
- Jul 02, 2009
Thanks so much for your advice, jsrock516.
I also checked and found the wiring harness unplugged. I wonder if it just shakes loose over time with this model of washer?
Again, great work!
-Yaddy in Canada
- Jun 19, 2009
Thank you very much. This fixed the problem. The wires had broke free from the temp probe connector. Your instructions made the repair very easy.
Thanks again.
Wayne
- Jan 04, 2009
Thank you!! Our Whirlpool front loader was showing the F-5 error. Thanks to some research on the web, particularly your article, I located the NTC sensor based soley on your advice and description. I found that it was simply unplugged. Plugged it back in and the washer works like a champ. I would have been pretty damn mad when I called out a repair man, watched him locate the problem and literally plug it back in, then charge me for a service call.
I cannot thank you enough!
Dan in California.
Featured Tip
nxt prv
Add a Comment
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
Can you Help with these Washing Machines problems?
Answer
the washer starts then stops after a while H F error appears. I have cleaned the filter and it... (More)
Answer
Our Hotpoint Aqualtis aqxxl 149 pi washing machine is stopping mid way through the cycle and is not... (More)
Answer
the tub fills with water when off. Also toward the end of the cycle it occasionally shuts down and... (More)
Answer
water not coming out strong enough in the dishwater.... water is turned on completely and nothing... (More)
Answer
My whites are not looking real white and occassionally get spots on them. I have been using the... (More)
Describe your problem:
Select a Category:
Insert Link
Insert Image
Insert List
Insert List
Spell Check
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washer & Dryer Repairmen
in Tulsa, OK
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
