Tip & How-To about iPhone Apps
How to unfreez an ipod
INSTRUCTIONAL STEPS
To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo show up on the screen:
How to unfreeze or reset an iPod Classic 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Now press and hold the Menu and Select buttons until the Apple logo appears, which may take about 6 to 10 seconds. You may need to repeat this step.
Notes:
  • If you are having problems resetting the iPod, go ahead and set it on a flat surface. Then make sure the finger pressing the Select button is not touching any part of the click wheel. Also be sure that you are pressing the Menu button towards the outside of the click wheel, not near the center.
  • If the above mentioned steps do not work, then you can try connecting your iPod to a power adapter and plug the power adapter into an electrical outlet, or connect the iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
How to reset an iPod Nano (1st, 2nd, and 3rd Generation) This one is similar to how you would do it for an iPod Classic:
You can also reset an iPod Mini in the same way as the above steps.
How to reset or unfreeze an iPod Shuffle 1. First , eject your iPod shuffle from iTunes, if you have it connected.
2. Then remove the iPod shuffle from the USB dock.
3. Move the switch that is on the top of the iPod shuffle to the off position.
Note: When iPod shuffle is off, the green stripe by the switch is not visible.
4. Wait 5 seconds.
5. Move the switch back to the on position so green stripe will be visible in either position.
And that's it! Hopefully, now that you know these steps, you don't have to keep taking out the battery to unfreeze your iPod! Any comments or questions, make sure to write below! Enjoy! Source: Apple Support
[tags]ipod, unfreeze ipod, reset ipod, how to unfreeze ipod, how to reset ipod, reset ipod nano, reset ipod classic, reset ipod touch[/tags]
Remember to leave your comeeent testimony and recommendation saying how helpful this tip is to you
iPhone Apps Logo
how can i reset my ipod?
Please follow the below steps to reset the iPod.
  1. Press and hold the "Sleep/Wake" button. This is the main power button on the top left-hand corner of the device.
  2. Press and hold the "Home" button while still holding "Sleep/Wake." The home button is the main button on the front of your iPod touch, indicated by a white square inside of a circular black button.
  3. Hold both buttons until the Apple logo appears on your screen. Resetting can take upwards of 10 seconds. Once the logo appears, your iPod touch reboots by itself.
Thanks for understanding.
Dec 30, 2011 | Apple iPod touch
my sons ipod touch hasnt been used for a couple of months & now it wont turn on or show any signs of charging. i have tried holding the on/off & home buttons without success, please help!
Restarting your device
Press and hold the Sleep/Wake button for a few seconds until the red "slide to power off" slider appears, and then slide the slider.
  1. Press and hold the Sleep/Wake button until the Apple logo appears.
    Follow these steps to reset your device
    Note: Reset your device only if it is no longer responding and the steps above do not work.
  1. Press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
Oct 07, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
my ipod touch is locked up for 21738236 minutes does any one now how to help me???
Have you reset it? if not
To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
If its not responding do a hard reset.
To reset it, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
Jun 29, 2011 | Apple iPod touch
my ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
My iPhone won't turn on! I've tried everything and I only get to the apple. HELP!
Try forcing an application to close
To force an application to close, follow these steps:
iPhone or iPod touch running iPhone OS 3.0 or later
  1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button.
  2. Instead of dragging the red slider, press and hold the Home button for six seconds.
  3. If the device does not return to the Home screen, see the steps below to restart.
iPhone or iPod touch running iPhone OS 2.2.1 or earlier
  1. Press and hold the Home button for six seconds.
  2. If the device does not return to the Home screen, see the steps below to restart.
If the iPhone or iPod touch remains unresponsive, try restarting the device:
Restarting iPhone or iPod touch
  1. To turn it off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPhone.
  3. To turn iPhone or iPod touch on, press and hold the Sleep/Wake button until the Apple logo appears.
If the iPhone or iPod touch remains unresponsive after trying the above steps or if it is in a different state, such as showing a persistent Apple logo on the display, try resetting the device:
Resetting the iPhone or iPod touch
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
Hope this helps...
Sep 03, 2009 | Apple iPhone Smartphone
686 people viewed this tip
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
