Tip & How-To about NRS Hoveround MPV 5 - Used Power Wheelchair
How to Diagnose Trouble Lights on Hoveround Power Wheel Chairs
Here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
when I switch on .all the lights sweep from green to red and chair wont function
Is the chair connected to the charger? If so, disconnect it then power the chair off then on again.
Dec 27, 2010 | Invacare Supply Group Invacare Pronto M91...
no power
1- Make sure that your batteries are fully charged and that they have not gone bad from sitting unused for a long time.
2- If the batteries are less than 2 years old and have been on the charger for at least 8 hours but the power chair will not power on when the charger is disconnected, you may be have blown a fuse. They are standard automotive fuses and are located inside the battery covers under the seat.
3- If you have checked on both 1 and 2 and still have issues or have blinking lights on the controller,
here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
Dec 26, 2010 | NRS Hoveround MPV 5 - Used Power...
WHY IS MY CONTOLLER FLASHING ? My power chair
Dec 22, 2010 | Invacare P9000 Xdt Motorized Wheelchair
lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Apr 10, 2009 | Pride Jazzy 1103 Ultra Standard Power...
lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
1,215 people viewed this tip
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
