Tip & How-To about Computers & Internet
How to prolong the life span of your laptop battery
Instructional steps
  1. 1Use the laptop on a hard surface. This allows proper air circulation and prevents overheating. Avoid using the laptop in temperatures over 80 degrees Fahrenheit.
  2. 2Remove the battery when using AC power. Once the battery is fully charged, there is no need to keep it plugged in. Residual charge drains the battery slowly, so when the battery isn't needed, take it out of the laptop and store it in a cool, safe place.
  3. 3Allow the battery to drain completely before recharging. This allows you to take advantage of the limited number of charge cycles the battery contains.
  4. 4Limit the amount of applications, programs and external devices used on the laptop at one time. Close anything that doesn't need to run. Multitasking causes the processor to run too hard, producing higher heat inside the laptop and draining the battery power.
  5. 5Use your laptop's power control program to automatically save power. Reduce the backlight on your laptop when it runs on battery power. Set the standby and hibernate modes for when you take breaks from working on the laptop.
  6. 6Store your laptop battery in a cool place. Avoid heat above 80 degrees Fahrenheit, direct sunlight and extreme cold.
Remember to leave your comeent abnd share your testimony by saying how helpful this tip is to you
Computers & Internet Logo
How to stop overheating of laptop?
Always place laptop on a hard surface/tabletop, never on a bed or soft ssurface. Air circulation of bottom of laptop is necessary for proper cooling.
Jun 15, 2012 | Amstron Toshiba Satellite T135D-S1324...
why is my laptop get's better warm and when i go into my facebook, couple of minutes later it shut off.
Your computer is overheating.
Turn it off.
Remove the battery.
Disconnect the AC adapter.
Buy a can of compressed-air.
Give your computer a "blow-job", to blow-out all the dust from inside the computer.
The dust is "insulating" your laptop, preventing it from cooling itself down.
Apr 18, 2010 | CMB T43 750 Notebook
laptop gets warm near touchpad , shuts down
Sounds like it is overheating and then shutting down. Is the laptop on a hard surface or a lap or blanket? You need to have air circulation.
Mar 13, 2010 | Medion MD 96340 Laptop
i have a acer aspire 5735 and the bottem of the laptop is overheating and very hot and it shuts down the computer i have to wait till it cools down before it switches on again can anyone help thanks
Best Practices To Avoid Notebook Overheating
To avoid chances of laptop overheating, please follow these practices:
Clean the ventilation openings of your laptop at regular intervals with compressed air.
Always place your laptop on a flat, hard surface like a table etc. Don't place your laptop on blankets or other soft surfaces that can block the fans and air vents on the bottom of the laptop.
Never put the laptop in a restricted space where heat can build up and cause issues.
Install monitoring applications on the laptop that enables you to track the temperatures of processors, hard drives and other system components.
Regulate and optimize the power settings suitably so that the heat generating parts – such as the LCD and storage disc drives – power down if they are not used for a period of time.
If find necessary, you should use a laptop cooling device or a stand for raising your laptop to minimize the chances of heating.
If you are facing overheating issues and the laptop is currently covered under warranty from the manufacturer, report the problems so that the issue can be resolved.
Sep 26, 2009 | Acer Aspire 5735 Notebook
235 people viewed this tip
David Payne
David Payne
