Tip & How-To about Microsoft MSDOS 6 Upgrade Operating System
How to find your MAC address using MS-DOS
The MAC address is the physical address your computer's Ethernet card or network interface card (NIC) uses to identify itself to other computers and devices on your network. There are different ways to find your Ethernet card's MAC address, depending on what operating system and programs you have installed. Since most Windows-based computers have access to the MS-DOS command prompt, using DOS to find your MAC address is one standard way to do it.
There are a couple of different tools you can use in MS-DOS to find your MAC address. All of them requiring opening a command prompt window, which you can do by typing "cmd" into the Run bar on the Start menu (or in Windows Vista or 7, you can type it into the Search bar instead).
- Getmac
Getmac is a utility that is included on Windows Vista computers and on newer Windows XP systems. Typing "getmac" by itself on a command line will return the MAC addresses of any NICs that you have installed in your computer. (If you have an Ethernet NIC and a wireless NIC, for example, Getmac will list the MAC addresses for both of them.)
- Ipconfig
Ipconfig is a command that will display your IP address if you are currently connected to a network. However, by adding the "/all" switch to it, you can also see your MAC address, as well as many other configuration settings. Type "ipconfig /all" and look for the line labeled "Physical Address." If you have more than one NIC, the MAC address for each NIC will be displayed separately.
Microsoft MSDOS 6 Upgrade Operating System Logo
how to change my mac address
Your MAC address (physical address) is baked into your NIC (network interface card). Your wireless NIC will have it's own mac from your wired NIC.
To change it you would need to replace the NIC itself. You can, as an alternative, spoof your MAC address with programs. It basically intercepts all the frames and swaps out your real MAC for your spoofed MAC.
If your using Linux, it should already be installed, from a terminal just type macchanger.
For windows you would need to download a program. This is a decent one for Windows.
http://www.technitium.com/tmac/index.html
Jan 26, 2013 | Linksys Wireless-G Broadband Router
Could not open youtube videos. Message shows .aui
AUI (attachment unit interface) is the 15-PIN
physical connector interface between a computer's network interface card (NIC)
and an Ethernet
cable. On 10BASE-5
("thicknet") Ethernet, a short cable is used to connect the AUI on the computer
with a transceiver on the main cable. In 10BASE-2
or "thinnet" Ethernet networks, the NIC connects directly to the Ethernet
coaxial cable at the back of the computer.
IEEE Hope that helps, Thanks, Sea Breeze
http://www.appliance911seabreeze.com
802.3,
the Ethernet standard, defines the AUI 15-pin physical layer interface. This
interface is also called a DB-15 interface or a DIX interface (DIX refers to the
three major companies who helped standardize Ethernet: Digital Equipment
Corporation, Intel, and Xerox
Oct 03, 2010 | YouTube Videos
what is mac address?
A Media Access Control address (MAC address) is a unique identifier assigned to network interfaces for communications on the physical network segment. Logically, MAC addresses are used in the Media Access Control protocol sub-layer of the OSI reference model.
MAC addresses are most often assigned by the manufacturer of a network interface card (NIC) and are stored in its hardware, the card's read-only memory, or some other firmware mechanism. If assigned by the manufacturer, a MAC address usually encodes the manufacturer's registered identification number. It may also be known as an Ethernet hardware address(EHA), hardware address, adapter address, or physical address.
Hope this information will help you.
Sep 20, 2010 | Computers & Internet
One of my computer will not connect to the internet when hard-wired through this router. Others do work and the wireless works flawlessly. The computer in question runs XP and can communicate with the router but has no internet access.
1. There may be 3 issues here to consider 1st :
a. the network card \
b. the Ethernet cable
c. the Ethernet port on the router defective.
2.Here is a instruction set to follow to see if your router is connected properly with the said pc :
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or firefox) on the computer that doesn't connect.
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. use a straight through Ethernet cord ( a know good one )\
8. verify that the network card is working by using a loop back ( that is ping the NIC card ( done by using dos command prompt>> loopback address is 127.0.0.1 this should yield 4 hops complete if the NIC card is working ( NIC = Network Interface Card)
I hope this helps. Have a great day!
This is for all routers to set up wirelessly.
Aug 23, 2010 | SMC WBR14-N Router
Can't find my MAC address
Hi, here is a solution for your problem: Obtaining your MAC address
Your MAC address will normally be on the box or registration card for your computer or individual ethernet card. If you can not find it, please follow the instructions below depending on your operating system.
Windows Vista:
  1. Click on Start Button.
  2. Click on All Programs.
  3. Click on Accessories.
  4. Click on System Tools.
  5. Click on System Information.
  6. Click on plus sign in front of Components.
  7. Click on plus sign in front of Network.
  8. Click on Adapter.
  9. Scroll down to your Network Interface Card and it will list the MAC Addresss. (Make sure you do not get the wireless adapter).
WINDOWS NT, 2000, or XP:
  1. Using your mouse, click on the Start Button.
  2. Click on Programs.
  3. Click on Accessories, and then Command Prompt.
  4. Once a small black window appears, type in ipconfig /all (with a space between the g and the /).
  5. Locate the number to the right of Physical Address. This is your MAC address.
WINDOWS 95/98/ME:
  1. After clicking on the Start Button, click on Run.
  2. In the white space of the window, type in the word winipcfg
  3. Click on "OK".
  4. Look under the info for the Ethernet adapter. (Your system may also have a modem.)
  5. The number next to "Adapter Address" is your MAC address.
Hope this helps.
May 10, 2009 | Computers & Internet
959 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
