Tip & How-To about Computers & Internet
How to Stream Music from Windows 7 ? Share Media on Wireless Network
You can listen to your favorite music without having to carry your laptop everywhere by sharing your music library on a wireless network. Here is a tutorial to show how to stream music from one laptop to another. Using this method digital media such as videos and pictures can also be accessed from anywhere easily. By the following method you can listen music or view your photos or movies stored in your computer from different places in the network.
First we'll connect the server laptop to a wireless home network. This laptop has Windows 7 with Media player 12 and it has all the music, videos and media that you want to share. Right-click on the Internet notification area and select 'Open network and sharing center'. Now, click on 'Connect to a network' and from the list of networks, choose the preferred one and connect. Enter the secure network key when prompted.
Let's create a 'HomeGroup'. From 'Network and Sharing Center', click 'HomeGroup' and then 'What is a network location?'. You'll see a window with three options. Select the first one that says 'Home Network'. In the following window, select what you want to share and click 'Next'. Follow the onscreen instructions and Click 'Finish'.
In 'Network and Sharing Center', click 'Change Advanced Sharing Settings' and make the changes. Then go to 'Media Streaming Options' and allow people you want access to your files. Open Windows Media Player, go to 'Stream' and click 'Automatically allow devices to play my media'. The content you chose to share is now on this network.
To access this content on a client PC or laptop, first connect the machine to the same wireless network as the server laptop, using the previous procedure. Vista users can right click and directly select 'Connect to network'. Assuming that both laptops are in the same network, open Windows Media Player and see of you can find the shared server laptop in the left pane.
To find shared media on the network and to share media from the client PC, in WMP, right-click on Library and click 'Media Sharing'. Here, you can allow or deny access to other PCs and find the media you're looking for. Click 'OK' when you're done. Now, the server PC will appear in WMP and other functionalities will remain same. You're now ready to play the music which is stored on the server PC.
Computers & Internet Logo
i forgot my phone password...
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 30, 2012 | Cell Phones
how do you connect a ps3 to a computer
Set up your PS3
Step 1: Make sure your PS3 is connected to the same network (via Ethernet or wireless) as your computer. You can check your connection by going to Settings > Network Settings.
Step 2: Go to Settings > Network Settings > Media Server Connection on your PS3 and set it to "Enabled."
Set up your computer (PC)
Step 1: Download and install the latest version on Windows Media Player.
Step 2: Go to Library > Add to Library and add folders you want your PS3 to access. All personal folders (Photos, Videos, and Music) are selected by default, but if you have media in other folders, add them.
Step 3:. Go to Library > Media Sharing, and check "Share Media." Press "OK," then wait a few moments for your PS3 to show up as one of the devices. Then select it, click "Allow," then "OK."
OR
Set up your computer (Mac)
Step 1: Download and install PS3 Media Server (free). This will allow your PS3 to "see" your Mac.
Step 2: Connect to the same network as your PS3.
Step 3: Go to Navigation/Share Settings and uncheck everything in the Thumbnails section (at the top). Then, at the bottom, add folders you want your PS3 to access. You can choose to add your entire hard drive, but it's helpful to add shortcuts to folders like Music, Videos, and Pictures.
Step 4: Go to Transcoding Settings, and change the Maximum bandwidth to 14 or 15. If you have a very strong network connection, leave it at 0. If you don't have a 5.1 surround sound theater, go to the "Number of audio channels" settings and change it to "Stereo."
Step 5: At the top, hit "Save" and "Restart HTTP Connection."
Stream your media
Step 1: Go back to your PS3, and your computer's name will be listed under the Photos, Videos, or Music tabs. You need to be in the Music section on your PS3 to play music, in the Photos section to see photos, and in the Videos section to play videos. You cannot play copyrighted material.
Here are a few extra tips:
  • When viewing a photo, hit the b_triangle.gif button to view extra options, like starting a slideshow of images in the selected folder.
  • When listening to music, you can keep it playing in the background by hitting the PlayStation (home) button.
  • You can copy music, photos, and videos onto your PS3 hard drive. When viewing a file, hit the b_triangle.gif button and select "Copy."
Jun 08, 2012 | Sony PS3 Component A/V Cable + USB Cable...
switch off laptop, turn it on again songs no longer in itunes library. please help?
Your library lists songs detected by the laptop but not on your laptop. It might be detecting your home network or a music player.
1. Launch iTunes.
2. Click the iTunes drop down menu at the top of the screen.
3. Select "Preferences"
4. Select "Advanced". Its icon is a gear, at the far right of the window.
5. Select "Copy files to iTunes Media Folder..." in the upper middle of the window.
6. Select "Sharing" at the top of the window Its roughly in the middle.
7. Select "Look for Shared Libraries."
Feb 04, 2011 | Apple iTunes
Want to know how I can listen to my music through my bluetooth
bluetooth is a type of wireless connectivity between supported devices. you can share music files with other mobile users through bluetooth , and you may use a bluetooth wireless headset to listen to the music files being played through your bluetooth enabled systems such as laptop and may also be supported by yuor phone.
Jan 17, 2011 | Cell Phones
162 people viewed this tip
David Payne
David Payne
