Home | All Products | Royal Professional Espresso Machine | Tips
Tips for Keeping your Saeco fully functional.
EspRoastTech
By Guru EspRoastTech
Rank: Guru
Rating: 94%, 77 votes
posted on May 27, 2008
Very Helpful
Here's a few Tips for the countless number of people having problems with the Saeco Line Super Automatics Machines.
These are more Suggestions if you will on what you can do that will help your machine last as long as possible.
Tip 1. Surge Protector. Get one and use it on your machine. About half of the problems associated with saeco's revolve around a power....or lack of power problem.
Even the smallest Surge can send your machine out of whack. Worse yet if it loses power while in mid cycle, it can jam the brew system.
Tip 2. Bottled Water. Coffee is 90% Water, so by contrast quality water will increase the quality of the cup. Try an artisan water like fuji or italian bottled water, or even filtered water. This small tip will not only keep your machine insides clean, it'll make for a way better espresso.
Tip 3. Ditch the Oiley Beans. All Super Automatic Espresso Machines, even the 20,000 dollar commercials have one major flaw. They Hate Oiley Coffee Beans. Why? Its simple, Oiley Beans Gum Up the inside of the grinder and brew drive system and clog them.
Another Reason to Ditch Oiley Beans? Being a 2nd Generation Artisan Roaster Oiley Beans scream a few things. Oiley beans are usually over roasted. The oil on the beans isn't a good thing, the oil represents the flavor oils from inside of the coffee emerging out. Once they become oxodized the coffee loses flavor almost immediately. Oiley beans are also a sign of beans that have aged, which again, is not a good thing. Proper Espresso Should have very little to no Oil on the beans with a Uniform Color Darker then a city roast.
They Only Time there is an exception is with a french or dark roast, where the ashy tones are allowed.
Best Advice here is try to find a local roaster. The quality is usually better then any of the commercial corperate counterparts and your actually supporting people like you. What kind of people is that??? People who have a genuine love for coffee and want people to share that love.
Tip 4. Descaling. Even with bottled water the machine should be descaled every other month. You have a variety of options here. I personally use cleancaf for its ease of use and the fact every packet has the instructions on them.
Tip 5. Brew Group Cleaning. Clean the Brew Group with Soapy Water. No chemicals necessary. You'll also need to purchase some silicone lubricant which is sold by saeco. It must be food grade. The lubricant is applied around the inside ridge of the puck area of the brew group. The first 3 coffee's on the machine should be tossed there after to clear it of residue.
Tip 6. Turn Machine off after each use. When you don't need it, don't leave it on. Leaving it on for long periods of time creates air pockets inside the boiler of the machine and can dry out the inner gasket of the boiler unless you have the new J Style Boilers that come with the newer lines from Saeco.
Tip 7. Be careful of your grinder. Firstly, I tell people every day. This machine is not ment to make commercial quality espresso. Its just not possible. It was ment to make for a better experience than the traditional italian moka pots that make fairly terrible coffee. If you want a stronger coffee, then the answer is in itself, try other coffee's.
The machine enhances good coffee, and by comparison, enhances the flaws in bad coffee. Inferior Coffee's will have little crema and bad taste. The machine will try the best it can to accomodate the coffee. The Elongated pre infusion cycle help take even the worst coffee and make it look like it gives increadible crema. The proof comes afterwards, where the crema will decipate from the bad coffee's but will stay strong on the true espresso blends.
Setting the grinder any lower then 2, regardless of the model, it warrent for clogging and/or damaging the unit. If the coffee is too fine, it'll clog the unit, and usually cause the brew drive to strip the gears and even worse, i've come across cases where its even broken the brew drive.
This concludes my Tips for Keeping your Saeco functional post. I hope this helps people and gives them incentive to step out of the box when it comes to conventional coffee's that are on the market.
Was this helpful?
Yes
No
13 people thought this was helpful
Comment #1
posted on Apr 06, 2009
Rusty101
By Apprentice Rusty101
Rank: Apprentice
Rating: 0%, 0 votes
If your Saeco trips a safety switch it is probably dripping water onto an electrical component, usually time for a service. In my case a perished O ring let water drip onto a heater element plug. Be careful these are not just ordinary O rings but are heat resistant.
Comment #2
posted on Jun 08, 2008
rantacco
By Apprentice rantacco
Rank: Apprentice
Rating: 0%, 0 votes
My Saeco has started to trip electrical fuzes when switched on. Started when descaling after a about a few minutes then subsequently tripped the fuse immediately every time it was swithched on. I thought this may have been an overheating protection problem, but surely that would trip an internal switch (rather than external fuze). Anyone got a fix or am I destined to remain coffee-less with the machine at the repair shop for weeks on end. Thanks.
Can you Help with these Coffee and Espresso Makers problems?
Saeco Royal Professional Espresso Machine
our Cafe Swiss S.I. Cs100 Typ 790 isnt working right. the...
milk is not aspirated from the milk container by the...
weak and changing steam i n Saeco Royal. Doesnt helt to...
Hi, I have a Royal professional machine. The little valve...
i have a saeco royal professional that I purchased 1 yr...
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Small Appliance Repair
