Tip & How-To about Computers & Internet
Disable Automatic Reboot after Windows Update
Have you seen the message
"Automatic Updates
Updating your computer is almost complete. You must restart your computer for the updates to take effect.
Do you want to restart your computer now?"
Automatic Windows updates are very good for computer security. However, when these Windows updates are downloaded and installed on your computer, if the updates require a reboot of your computer, Windows keeps prompting you to reboot your computer.
Now, Windows XP Pro users can disable automatic reboot of the computer after a Windows Update. In order to do that, follow these steps
Disable Automatic Reboot after Windows Update for Windows XP Pro usersWith this setting you will be able to specify that after a scheduled Windows update, Automatic updates will wait for the computer to be restarted by any user who is logged on, instead of causing the computer to restart automatically. If this setting is not enabled or not configured, your computer will prompt you every 5 minutes to restart the computer to complete the installation.
1. Press + R which will launch the Run command. Type gpedit.msc and press Enter
2. Group Policy Editor will now be launched
3. On the left hand pane, under Local Computer Policy, click on the (+) sign next to Computer Configuration
4. Click on the (+) sign next to Administrative Templates. Then click on (+) next to Windows Components and then click on Windows Update
5. Double click on No auto-restart for scheduled Automatic Updates installations. A settings window will now open. In there, select Enabled and then press OK
6. Close the Group Policy Editor
Disable Automatic Reboot after Windows Update for Windows XP Home usersThe settings are a bit different for Windows XP Home users because there is no group policy configuration for Windows XP Home.
1. Press <Windows Key> + R and type in regedit. Press Enter
2. Navigate to
HKEY_LOCAL_MACHINE SoftwarePolicies MicrosoftWindows WindowsUpdateAU
3. Change the "NoAutoRebootWithLoggedOnUsers" DWord value to 1 to Disallow auto reboot.
4. Press OK
if this tip really help u pls vote ,...........shailendra
Computers & Internet Logo
Sony VAIO Laptop does not shut down with message "Please do not unplug updaing 11 of 55"
that message is from the automatic updates windows makes from time to time ...and this message usually appears after a fresh install with the operation system out of date ..and if you have the automatic updates ticked for to be made automatically ..The thing to be done is either let it install the updates...and it will shut down by itself...or ..start windows..and go to control panel ..and on the automatic updates...stop the updating process..This will cause a message to appear in the tray system every time ..to warn you that your computer is out of date ..and so ...but it has no real distress cause it will run like a charm even without the updates...(probably even faster ..cause if your computer is a little limited in resources the updates will slow it down a little ..
So ..this message is not a pest ..but the windows updating your operation system ..the only issue is when it is in error and takes more than the time it should ...usually it should not take more than a couple of hours for all 55 updates to be installed ...and this in case you have a slow computer...
Nov 04, 2011 | Sony VAIO Notebook
acer aspire one zge netbook wont update windows
Check the TIME and DATE settings, Set Correctly, then you will be able to Update...
Oct 14, 2011 | Acer Aspire One Netbook 8.9" Notebook
downloaded windows automatic update stuck on 3 of 3 for last few days. tried last known good config does nothing, i always return to updating 3 of 3 cannot get my comp to do anything else. help desperately needed please, whatever hair i did have left has now gone.
An issue has been identified by Microsoft that, after installing Windows Updates, a Computer displays a Configuring updates: stage 3 of 3. 0% complete message, reboots, comes back to that message again, and repeats the cycle. This problem occurs when Windows Update is attempting to install update 937287.
Follow this procedure to resolve the error:
1. Remove all connected peripheral Devices from the Computer.
2. Press and hold the power button until the Computer completely shuts down.
3. Unplug the power cord from the wall outlet.
4. Leave the Computer without any power for at least 30 seconds.
5. Reconnect the Computer to the power supply and then turn it back on.
6. Allow the Computer to start normally.
NOTE 1: Once the Computer has completely started into the Operating System, Windows Updates should automatically finish installing the update. If the update again fails to install completely, restart the Computer in Safe Mode (by tapping the F8 Kay at Start-up) and use the System Restore feature to return the Computer to a time before the issue started.
Click the Start -> All Programs -> Accessories -> System Tools -> System Restore.
NOTE 2: To avoid this issue, obtain and install update 937287 from the Microsoft Download Center separately from all other updates on the Windows Update site. Install the update that applies to your version of Windows Vista so that you can successfully install future updates.
For more information about this error, refer to the Microsoft KB Article ID 949358.
Good Luck!!!!!!!!!!!!!!
Dec 01, 2009 | Dell Computers & Internet
my laptop was running updates when the power was shut off. now it says installing update 3 of 3 0% complete and restarts over and over. how can i fix this?
Use the roll back feature to restore the computer to a date prior to updating, restart and then do the updates
Oct 09, 2009 | Computers & Internet
185 people viewed this tip
David Payne
David Payne
