Tip & How-To about Televison & Video
How to replace your TV tuner "F" connector.
You were moving your TV but forgot to remove the cable.
Suddenly you get to the end of the coax's length and keep on going. Out comes the "F" connector from the tuner. What do you do now?.
If you were lucky you can install a new "F" connector with some work. If you were not lucky you will have to install a new tuner. If you do not have the skills necessary to install the "F" connector (it is tedious), you may want to opt for a new tuner which should not be that expensive anyway.
If you have good soldering skills and can work on small items you may be able to do this. It requires removing the lower back of the unit, removing the board that the tuner is mounted to.
Depending on the type of TV, Direct view, LCD flatscreen or projector there are various ways the board could be removed.
Usually the tuner is on the small signal board. To remove this board you will need to take out all the screws around the perimeter so the board can be lifted out.
Some units also have plastic fasteners which need to be popped loose. They are pushed up through the board and help to stabilize it. The hold down method should be obvious if you study the board.
Once the board is removed turn it over to the solder side and unsolder the tuner and remove it from the board. Next you will need to pry the sides off the tuner.
Mark them left and right or in some method so you can reinstall them on the proper side. They generally have grounding tabs which need to be located in a particular space.
Once you can see the solder side of the board check it for cracks or damage and if possible remove the old connector wire from the "F" connector.
If the board is damaged you may have to replace the tuner. They are available at http://www.encompass.com and usually are under $50 US.
Order a new one, reinstall it and reassemble the unit and your unit should be ready to operate.
If the board is not damaged you will need a new "F" connector for PC board mounting.
They are available at http://www.mcminc.com .
When you get the part you will have to fit it to the unit and solder it into place. This should be obvious. I always solder the connector to the tuner case the entire circumference of the connector and have never had any repeat repairs. To do the soldering on that you will need a 120/140 watt soldering gun. They are available at http://www.mcmelectronics.com .
If the board has no hidden cracks it should work when reassembled. Reassemble the tuner, install in the board, reassemble the TV and you should be operational.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Televison & Video Logo
looking for cable with analog on one end and coax on other end
Since you're going to be soldering anyway, these are available on ebay. Just keep your wire as short as reasonable.
The other way is just grab a short f-type to f-type coax (standard TV coax cable) , and cut off one end. Then unweave the shield and solder into a bundle with a short wire to the TV antenna ground.
Sep 11, 2016 | Westinghouse Televison & Video
how do i connect catv conveter onto a tv
There are a few ways to do that. It depends on the connections the tv and the converter have.
1st way is to take a coax jumper from the box to the tv coax input. Coax meaning cable wire that screws on like the wire coming from the outside to the box.
2nd way is to use red yellow white tri-cable, or audio visual cables if the tv has them as inputs, the color of the ends is the same as on the input ports.
3rd way is to use a component cable. These are the 5 connectors bunch which have 3 video and 2 audio and go to the same colored component video in.
Jul 07, 2009 | La Crosse Radio Controlled Atomic Clock
Coax that looks like RCA?
There is a distinct difference between coax and phono (rca) cabling. Coax, sometimes called RF, is a cable that carries audio and video at the same time, what we call a "modulated" signal. RF connections look as if they are threaded on the chassis of your TV or VCR etc. A lone "Phono" cable moves either audio or video, but not both at the same time, unlike coax.
If you are attempting to patch RF, your cable must be coax at both ends.  Hope that helps.
Jan 07, 2009 | Apex Digital AT2014DV 20 in. TV/DVD Combo
loose cable connection plug
tv back cabinet to second hole to fixing cable hooked
Aug 23, 2008 | RCA F27442 27" TV
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
965 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
