Tip & How-To about Refrigerators
How to unclog fridge drain hose.
If your fridge is leaking on the floor your drain hose could be pluged with goo.pull out fridge and find the drain tube if possible.once you have found it you can blow air through it to dislodge anything that could be causing it to not drain.from the inside you can use acotton swab to clean out the hole with a small amount of soap and water or bleach and water. also if water is draining inside fridge this could be the problem.
Refrigerators Logo
AC unit is leaking
The drain tube is pluged take the hose off at the unit try blowing in it chances are its pluged and the condensation can't drain
Jun 27, 2013 | Heating & Cooling
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Whirlpool Refrigerator Model # ET21PKXGN00
HI thanks for your question. the problem is with the drain tube, from freezer to the drain pan ,located at the back, by the compressor. to repair. turn fridge off, for 24 hrs. pull fridge away from the wall. clean all the coils. locate the drain tube, by the drain tray. get a small plastic hose, shove the plastic hose up the drain tube. and blow, to dislodge any debris clean the tube thanks the appliance doc.
Oct 15, 2008 | Whirlpool Refrigerators
water leaking from bottom of fridge
usualy a pluged drain tube , at the raer top of the refrig compartment you may see a drain cup dipending on modle of fridge . if so gently pull staight out from rear wall and clean cup . there is a posibility there is a plugged drain above in the freezer compartment . this will require a service man.
while you have the cup out its a good idia to use a small hose to blow out the drane leeding out the rear and down to the compresor compartment as well ' hope this helped..
Oct 06, 2008 | Frigidaire Refrigerators
Up right 14.7 cu GE freezer
HI to clean the drain tube. pull fridge away from the wall .find the drain tube, by the drain tray. push a small plastic hose, up the drain tray. blow in the hose, to clear the debris. thanks the appliance doc.
Jul 28, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
773 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
