Tip & How-To about Razor 300001-SL Ground Force Go Kart
How to turn little batteries into bigger ones in emergancy
Roll up some tin foil flatten it to the size of the battery you need,circumfrence not the actual size of battery,push it against the spring where you would normally put the bigger battery then push the little battery on on top so it fits tight in the slot for the battery,WALLA,you now have power.its the same principle with all batteries.
Razor 300001-SL Ground Force Go Kart Logo
Oven door will not remain fully closed
Noiselab is not correct for all cases. As Buzz says, if the springs are strong then the foil fix works and works really well. Refer to attached photo for guidance in conjunction with instructions below. Note my possibly simpler answer at bottom.
I cut some short narrow strips (about 4mm x 20 mm) from a tin can and folded them over into a flattened "U". You can back off the large Phillips head screw on the frame of the oven where the door hinges are inserted and sit the tin over the little plate that is held by these screws and then tighten so that one end of the "U" sits between the oven chassis and the adjustment plate. If it still doesn't quite close add more tin as required. Refer photo for terminology.
Now the simpler solution which I didn't try but which would probably work after I contemplated the problem in retrospect is this. The reason I didn't think of this was that I thought the hinge went into a tube or slot. Later I realised it is just a simple cantilever design which is why the tin foil solution works (ie lifting the middle support of the cantilever produces a corresponding closure of the door). When I inspected the large Phillips head screws to insert the tin foil these were completely loose. Try this first then. Slide the adjustment plate up as high as the tolerance of the Phillips screw allows and then tighten it off hard. This will raise the bottom edge of the plate just as the tin foil method does. If not enough then proceed to the tin foil method.
Jul 09, 2010 | AGA ILVE M-90F-MP Dual Fuel Range
the spring has broken off one of the battery connections
Try folding tin foil into a small small square that will fit between the battery and the end where the spring was.. Make the little square thinck enough to put a little tention on the battery - to hold in in there..
Jul 27, 2009 | Texas Instruments TI-83 Plus Calculator
my xbox360 (wireless) controller keeps turning off if a lil shake is applied to it. (brand new batteries in it) it just keeps turning off and its not just one, it both of mines!
Take the battery pack off, there are two coiled springs that touch the batteries.
Stretch these springs up slightly, but not too much.
Then replace the battery pack.
Jul 15, 2009 | Microsoft Xbox 360 Controller
Sharper Image iTower remote not working
I put a small piece of tin foil on the negative side of the battery and the remote worked again.
Mar 28, 2009 | Electronics - Others
710 people viewed this tip
Top Razor Toys Experts
Clif Roberts
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
