Tip & How-To about Toys
Turn AAA batteries into AA batteries in emergancy
All you need to do is roll up some tin foil into a flat circular shape the size of the battery that you need,circomfrence,not the actual size of the battery,put it against the spring on what ever gadget you need the batteries 4,then push the little AAA battery on the tin foil so it fits tight into the slot where the AA bigger battery should be and WALLA, sorted.your gadget should now work,and its the same principle with all batterys.
Toys Logo
thin vertical line on screen shows what another part of screen is
Ah, the "line of death."
There sure is & best of all, it's FREE. You will need a piece of tin foil rolled up to a pencil's thickness. You will also need some patience to watch THIS video, which shows you the placement for the tin foil. As pointed out in the video, you only need to remove the face plate & NOT all of the buttons, D-pad.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Slim...
Sharper Image iTower remote not working
I put a small piece of tin foil on the negative side of the battery and the remote worked again.
Mar 28, 2009 | Electronics - Others
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
1,564 people viewed this tip
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
