Tip & How-To about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Networking Issues
Problem: Network Cable Unplugged
Description: Don’t take this message literally - there are many causes besides not having a cable physically plugged into the network card. The message really means that the network card doesn’t detect a live link to another device on the other end of the cable.
Possible Solutions:
Download and install the latest network card driver program.
Check the cabling - a bad cable will prevent link detection. Substitute a cable that’s known to be good.
Check the link lights on the device on the other end of the cable, whether it’s a hub, switch, router, or a NIC in another computer. It should show a live link to the NIC. If it doesn’t, try a different port.
Auto-detecting speed and duplex mode can be unreliable. Set them manually. Most routers and switches use 100Mb, full duplex. Hubs can only use half duplex.
Problem: Renewing a DHCP lease fails, with error message “An error occurred while renewing interface : The system cannot find the file specified.”
Problem: Network connection configured to obtain an IP address automatically has IP address 0.0.0.0
Solution: Make sure that the DHCP Client service is running:
Right click My Computer, and click Manage.
Double click Services and Applications.
Double click Services.
Double click DHCP Client. If the Service status is Stopped, click Start.
Set the Startup type to Automatic.
Thanks to Lightcap, who suggested this fix in a news group message.
Problem: Network Connection Has IP Address 169.254.x.x
Description: The network card is configured to obtain an IP address automatically, and it’s connected to a network with a DHCP server: hardware router, another computer running Internet Connection Sharing, cable modem, DSL modem, etc. But it gets a 169.254.x.x IP address, which indicates that it can’t communicate with the DHCP server:
Possible Solutions:
Connect the computer using a different Ethernet cable or hub/switch/router port.
Download and install the latest firmware for the hardware router.
Disable XP’s Internet Connection Firewall <../xp/ic_firewall.htm> on the local area network connection.
The card is configured to automatically sense network speed and duplex mode, but auto-sensing is failing. Configure the speed and duplex mode manually. For example, most switches and routers use 100 Mb speed and full duplex. To make the settings, right click the network connection and click Properties | Configure | Advanced.
Un-install the network card and move it to a different slot.
If you have a cable modem connection, turn off the computer, turn off the cable modem, and wait a few minutes. Turn on the cable modem, and then turn on the computer.
Error Message: An error has occurred while trying to share . The Server service is not started. The shared resource was not created at this time.
Solution:
To start the Server service:
Right click My Computer and select Manage.
Scroll down the list of services and double click Server.
Click the Start button.
Click Apply and OK.
Problem: Computer A Can Ping Computer B, but not Vice Versa
Solution: This is almost always caused by an improperly configured firewall on Computer A.
Problem: One Computer Can’t Access Some Web Sites, but Other Computers Can
Solution: Look for the Windows Hosts file on the problem computer:
Windows 95/98/Me: C:\Windows\Hosts
Windows 2000: C:\WinNT\System32\Drivers\Etc\Hosts
Windows XP: C:\Windows\System32\Drivers\Etc\Hosts
Open it with a text editor and you'll probably find lines with the names of the sites that you can't access. Delete those lines, save the file, and try again. If those are the only lines in the file, delete the file. Be sure to save it with a file name of just Hosts, with no file type. If your editor saves it as Hosts.txt, rename it to just Hosts.
The Hosts file can be created by "web accelerator" programs that store name-to-IP address translations. This might speed up access by a tiny amount, but it causes problems when a site's IP address changes.
Problem: A shared disk or folder doesn’t appear in My Network Places
Description: The disk or folder is shared correctly on another computer, but it doesn’t appear.
Solution 1: Click Add a network place and follow the prompts to add it. Browse to it through Entire Network, or specify the path name using the form \\computer\share.
Solution 2: Click View workgroup computers, then click the computer that has the shared disk or folder.
Problem: XP's Network Setup Wizard Says That No Network Card Is Installed
Solution: XP's Network Setup Wizard sometimes fails to recognize an installed and working network card. This is because the NIC's driver program doesn't respond correctly to all of the queries that the Wizard makes when it's looking for a NIC. Configure the card’s TCP/IP properties manually. Here’s how to do it for Windows 95/98/Me <../ics/icsclient.htm>, Windows 2000 <../ics/ics_win2k_client.htm>, and Windows XP <../xp_ics/clientwiz.htm>. Then set the workgroup name to MSHOME.
Problem: Windows XP takes a long time to open a shared disk or folder on a computer running Windows 95, 98, or Me
Description: This is a different problem than My Network Places taking a long time to open . This problem occurs after you double click a shared disk or folder.
Possible Solutions:
Disable searching for scheduled tasks
This Microsoft Knowledge Base article <http://support.microsoft.com/default.aspx?scid=kb;en-us; Q245800> describes a bug in Windows 2000 Professional that might also exist in Windows XP. Disable searching for scheduled tasks by deleting this registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\
CurrentVersion\Explorer\RemoteComputer\NameSpace\
{D6277990-4C6A-11CF-8D87-00AA0060F5BF}
· Delete stored network passwords
1. Click Control Panel | User Accounts.
2. Click your user name.
3. Click Manage my network passwords.
4. Click each entry and click Remove
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they connect fine but cannot connect through my vista laptop. I have enabled a wpa key on the connection. When attempting to connect to internet the network shows as unidentified with a cross to internet connection. Any help would be appreciated. I have an aspire 5315 laptop running windows vista home. I am using a virgin modem. The ip config is Microsoft Windows [Version 6.0.6002] Copyright (c) 2006 Microsoft Corporation. All rights reserved. C:\Users\ang&gt;ipconfig/all Windows IP Configuration Host Name . . . . . . . . . . . . : ang-work Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Mixed IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : cable.virginmedia.net Wireless LAN adapter Wireless Network Connection: Connection-specific DNS Suffix . : cable.virginmedia.net Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48 Lease Expires . . . . . . . . . . : 28 February 2011 13:53:47 Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 151002585 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0E-A4-58-CB-00-1B-38-63-2C-AD DNS Servers . . . . . . . . . . . : 192.168.0.1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : cable.virginmedia.net Description . . . . . . . . . . . : Broadcom NetLink (TM) Fast Ethernet Physical Address. . . . . . . . . : 00-1B-38-63-2C-AD DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : cable.virginmedia.net Description . . . . . . . . . . . : isatap.cable.virginmedia.net Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 9: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 02-00-54-55-4E-01 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes C:\Users\ang&gt;
Everything looks normal:
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
a network cable is unplugged
This message " A network connection is unplugged" comes when the connection unavailable may be due to faulty connection. Chek that your router is rightly plugged and the sockets are dust-free. If problem persists, contact support.
Aug 14, 2009 | D-Link Computers & Internet
Network cable unplugged
Since it only happens when it rains, it sounds like you may have damaged cable between the modem and the drop. You will need to physically inspect whatever cables you have access to, and you may need to call a field tech out to repair the damaged cable.
Nov 05, 2007 | Arris SURFboard SB4220 Modem
392 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
