Tip & How-To about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Error "0x000000E4" or "0x0000000A " in Windows Vista
Error message when a portable Windows Vista-based computer that has an integrated or external USB camera device resumes from long-term suspend mode: "0x000000E4" or "0x0000000A "
To successfully apply this hotfix, you must create the ForceHCResetOnResume registry entry. To do these, follow these steps: 1. Click Start , click Run , type regedit in the Open box, and then click OK .
2. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{36FC9E60-C465-11CF-8056-444553540000}\
Notes :-
is a placeholder for the USB devices on the system.
• In this step, you must locate the registry subkey that represents the system's USB universal host controllers. The USB universal host controllers typically have the lowest four-digit numbers.
3. On the Edit menu, point to New , and then click DWORD Value .
4. In the details pane, type ForceHCResetOnResume, and then press ENTER.
5. Right-click ForceHCResetOnResume , and then click Modify .
6. In the Edit DWORD Value dialog box, click Decimal under Base .
7. In the Value data box, type 1, and then click OK .
8. Close Registry Editor.
9. Restart the computer.
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3 none
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
What does Windows Vista error 0x00000005 mean?
Applications that are reading file allocation table (FAT) based storage devices at the time of a resume may receive the following error message from the file system: ERROR_ACCESS_DENIED (0x00000005) This occurs although the file has appropriate sharing and access permission.
Examples of storage media that frequently use the FAT file system on Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and the Secure Digital (SD) Memory Card.
This behavior is observed when using Pocket PC 2002 Adaptation Kit Update 4 (AKU4) and later.
RESOLUTION:
Applications can handle this situation by detecting the specific error code while reading a storage card file, and then retrying for a short period until the device is ready. The following is an example C code fragment that demonstrates this concept: while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) &&
( ERROR_ACCESS_DENIED == GetLastError() ) )
// Access Denied: Maybe the file system is not ready yet.
tries++;
if ( tries > 4 )
break;
Sleep(500);
// It has been a few seconds. The file cannot be accessed.
You can use the same approach for other programming languages. For applications that access the storage card through middleware libraries that do not provide direct access to the file system, you may have to implement transactional or block verification methods to get reliable data transfer across a suspend resume.
Mar 09, 2009 | Microsoft Windows Vista Home Premium with...
imation atom usb driver vista
vista has this problem , see below webite
Error message when you try to install a new hardware device on a Windows Vista-based computer: "Windows encountered a problem installing the driver software for your device GET basis information
http://support.microsoft.com/kb/940199/en-us
Jun 06, 2008 | Electronics - Others
896 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
