Tip & How-To about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Issue with hybrid sleep feature and hibernation feature in Windows Vista
The hybrid sleep feature and the hibernation feature in Windows Vista may become unavailable after you use the Disk Cleanup Tool SYMPTOMS
To resolve this problem in Windows Vista, run the powercfg -h on command at a command prompt to enable the hibernate feature and the hybrid sleep feature.
To run this command, follow these steps:
1. Click Start , click All Programs , and then click Accessories .
2. Right-click Command Prompt , and then click Run as administrator . If you are prompted for an administrator password or for confirmation, type the password, or click Continue .
Type powercfg -h on, and then press ENTER.
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
how i can enable hibernate option
xp
To automatically put your computer into hibernation
You must be logged on to your computer with an owner account in order to complete this procedure.
1. Open Power Options in Control Panel. (Click Start, click Control Panel, and then double-click Power Options.)
2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
vista
Go to the command prompt icon in the Start menu under Accessories and right click the icon: click "Run as administrator".
Paste: "powercfg.exe /hibernate on" and hit Enter and also paste "powercfg -h on" and hit enter just to be safe.
Open Control Panel and type in "Hibernate" in the Search.
Click "Turn hibernation on or off"
Click "Change advance power settings"
Scroll to and expand the "Sleep" option.
Select "Off" to the "Allow hybrid sleep" option.
Scroll to and expand the "Power buttons and lid" option.
Select "Hibernate" for the "Sleep button action" option. 10. Select "Hibernate" for the "Start menu power button" option.
windows 7
Click the Start button, and then click the arrow next to the Shut down button.
Sleep and Hibernate located on the menu
If sleep or hibernate aren't available, it might be for one or more of the following reasons:
Dec 05, 2010 | Dell OptiPlex GX620 PC Desktop
my laptop was on hibernation. now it is not booting. please help
Hibernation is enabled by default in Windows Vista, and is one of the seven options (i.e. Hibernate) that appears on the Vista shutdown menu. Hibernate your Vista system will enable you to quickly restore to existing system state and intact workspace instead of start afresh, run programs and open your documents one by one again. If you do not use the hibernate feature in Vista, and want to delete hiberfil.sys and then recover the space occupied by the big hibernation storage file, the hibernation function can be turned off and disabled.
Unlike Windows XP, users cannot turn the hibernation on or off via Vista GUI interface anymore. Previously users can enable or disable hibernation via Power Options applet in Control Panel. This option no longer available in Windows Vista, which also enables Hibernate ability and creates hiberfil.sys by default. Instead, users have to rely on command line utility Powercf and Disk Cleanup Wizard to disable hibernation in Vista. Microsoft KB920730 provides details on how to disable and turn off hibernation on computer running Vista system. You must log on to Vista with user account in Administrators group to perform these action.
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
If you are prompted by User Account Control for permission, click Continue.
At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
Type exit, and then press ENTER.
Another easier workaround for those who’re not comfortable to work with command line is to disable hibernation and hybrid sleep feature in Windows Vista is by using Disk Cleanup wizard tool, the built-in Windows disk cleaner to delete hiberfil.sys file. The hibernation file must be enabled to access the hybrid sleep feature and the hibernation feature in Windows Vista.
Click Start button, then go to All Programs -> Accessories -> System Tools, and run Disk Cleanup.
Choose which files to clean up, either My files only or Files from all users on this computer is fine.
On “Drive Selection”, select the Windows Vista boot drive to clean up. Note that you must select the drive where Vista is installed, which normally is also the boot drive (C:) as hiberfil.sys file will be located on the root folder of it.
Once Disk Cleanup finishes scanning the system, Disk Cleanup for Vista window will open.
Select and tick the check box next to the Hibernation File Cleaner.
You can select or deselect other type files to clean or preserve from the available items or options in the list provided.
Click OK button when done.
Hibernation will now be removed and disabled.
It will solve your problem.
Dec 28, 2009 | HP Compaq Presario V3000T Notebook
Screen goes blank after hibernation - Dell Inspirion 530 Vista
Turn off vista hybrid sleep and hibernation mode. It causes more problems then it helps.
Jun 25, 2009 | Computers & Internet
396 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
