Tip & How-To about Computers & Internet
HOW TO CONNECT - INVALID IP ADDRESS - 169.254 ..IN VISTA
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Remember 196.254.x.x mostly we call bad ip address in fact this is not a bad ip address, The INTERNET ASSIGNED NUMBER AUTHORITY(IANA) has reserved the private ip address in the range of 169.254.0.0 to 169.254.255.255 for automatic private addressing. So this addresses are not found on internet. That is the reason we cannot go online with this ip addresses normally.
TRY FOLLOWING STEPS
  • Power cycle the system
  • Make the BIOS default
  • Check in Safe Mode with networking it the computer is going online,Try system restore if computer was going online before
  • Release and Renew the IP address
  • Turn off the firewall (Click on start >Type Windows Firewall inthe instant search box>Click on Windows Firewall>Click Off on the Windows Firewall Screen>Click OK>Restartthe computer)
Run Network Diagnostics
Click on Start> Type Network in theinstant search box> Click on Network and Sharing Center> Click on Diagnoseand Repair on the right hand side
Reinstall Network Card
Go to device manager> UnderNetwork Adapters, right click on the network card> Clickon Uninstall> Restartthe computer
Disable any Wireless Card
Go to device manager> Under Network Adapters, right click on the Wireless Card> Click on Disable> Restart the computer
Disable IPV6 ADDRESS
Click on start> Type Network in the instant search box>Click on Network and Sharing Center> Click on Manage Network Connections> Right Click on Local Area Connection> Click on Properties> Uncheck Internet Protocol Version 6 (Ipv6)> Click OK> Restart the computer
RESET WINSOCK AND TCP/IP STACK
Click on run>type cmd>press enter>on the black screen type the following commands.
netsh winsock reset> netsh int ip reset log.txt> Restart the computer
Create a new connection Manually
Click on start> Type Network in the instant search box> Click on Network and Sharing Center> Click on Set up a connection or network> Select Connect to Internet and then click Next> Select No, Create a new connection and click Next> Click on Broadband> Type ISP User name and Password, Type the Connection Name then click on Connect
STILL IT IS NOT GOING ON LINE NEED TO PULL THE COMPUTER TO THE FACTORY DEFAULT SETTING
***(NOTE:- YOU WILL BE LOOSING ALL THE DATA FROM THE HARD DRIVE)
Computers & Internet Logo
http//192. 168.0. 101 :8080
NetName: PRIVATE-ADDRESS-CBLK-RFC1918-IANA-RESERVED
NetHandle: NET-192-168-0-0-1
Parent: NET192 (NET-192-0-0-0-0)
NetType: IANA Special Use
OriginAS:
Organization: Internet Assigned Numbers Authority (IANA)
RegDate: 1994-03-15
Updated: 2013-08-30
Comment: These addresses are in use by many millions of independently operated networks, which might be as small as a single computer connected to a home gateway, and are automatically configured in hundreds of millions of devices. They are only intended for use within a private context and traffic that needs to cross the Internet will need to use a different, unique address.
Comment:
Comment: These addresses can be used by anyone without any need to coordinate with IANA or an Internet registry. The traffic from these addresses does not come from ICANN or IANA. We are not the source of activity you may see on logs or in e-mail records. Please refer to http://www.iana.org/abuse/answers
Comment:
Comment: These addresses were assigned by the IETF, the organization that develops Internet protocols, in the Best Current Practice document, RFC 1918 which can be found at:
Comment: http://datatracker.ietf.org/doc/rfc1918
Ref: https://whois.arin.net/rest/net/NET-192-168-0-0-1
OrgName: Internet Assigned Numbers Authority
OrgId: IANA
Address: 12025 Waterfront Drive
Address: Suite 300
City: Los Angeles
StateProv: CA
PostalCode: 90292
Country: US
RegDate:
Updated: 2012-08-31
Ref: https://whois.arin.net/rest/org/IANA
OrgAbuseHandle: IANA-IP-ARIN
OrgAbuseName: ICANN
OrgAbusePhone: +1-310-301-5820
OrgAbuseEmail: abuse@iana.org
OrgAbuseRef: https://whois.arin.net/rest/poc/IANA-IP-ARIN
OrgTechHandle: IANA-IP-ARIN
OrgTechName: ICANN
OrgTechPhone: +1-310-301-5820
OrgTechEmail: abuse@iana.org
OrgTechRef: https://whois.arin.net/rest/poc/IANA-IP-ARIN
Dec 06, 2013 | Computers & Internet
whats an ip address
An Internet Protocol address (IP address) is usually a numerical label assigned to each device (e.g., computer, printer) participating in a computer network that uses the Internet Protocol for communication.[1] An IP address serves two principal functions: host or network interface identification and location addressing. Its role has been characterized as follows: "A name indicates what we seek. An address indicates where it is. A route indicates how to get there."
The designers of the Internet Protocol defined an IP address as a 32-bit number[1] and this system, known as Internet Protocol Version 4 (IPv4), is still in use today. However, due to the enormous growth of the Internet and the predicted depletion of available addresses, a new addressing system (IPv6), using 128 bits for the address, was developed in 1995,[3] standardized as RFC 2460 in 1998,[4] and is being deployed worldwide since the mid-2000s.
IP addresses are binary numbers, but they are usually stored in text files and displayed in human-readable notations, such as 172.16.254.1 (for IPv4), and 2001:db8:0:1234:0:567:8:1 (for IPv6).
The Internet Assigned Numbers Authority (IANA) manages the IP address space allocations globally and delegates five regional Internet registries (RIRs) to allocate IP address blocks to local Internet registries (Internet service providers) and other entities.
Apr 01, 2011 | Sony Playstation 3 (PS3) Console
my router can not access dhcp.Why?
A DHCP Reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. You can use these reservations for DHCP-enabled devices like print and file servers or other application servers which always have the fixed IP address on a network.
To configure a DHCP reservation, follow the steps provided below:
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click Setup > Basic Setup.
Step 3:
Make sure that the DHCP Server option is Enabled. Click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Step 4:
When you click on DHCP Reservation, a new web browser window will pop-up. Click the Select checkbox to reserve a client's IP address. Click the Add Clients button afterwards.
kb17362-003_en.png Step 5:
If you want to manually assign an IP address, enter the client's host name in the Enter Client Name field. You can do this as well in the IP Address and MAC address fields.
Step 6:
Click the Add button.
Step 7:
A list of DHCP clients and their fixed local IP addresses will be displayed at the bottom of the screen. If you want to remove a client from this list, click the Remove button.
On this window, you can do any of the following:
• Click the kb17362-006_en.png button to save your changes.
• Click the kb17362-007_en.png button to cancel your changes.
• To view the most up-to-date information, click the kb17362-008_en.png button.
• To exit this screen, click the kb17362-009_en.png button
If you need more help come back.Post / thumbs / testimonial are welcome!.
Nov 20, 2010 | Linksys WRT160N Wireless Router
default ip address?
Hi,You are right mvincentc , for more IP related informations you can use this http://www.whoisxy.com/ site for best result.here only i got my exact address and other details,It is totally free site .visit here for more details.
Jun 05, 2010 | Milan Technologies ShAir AccessG Pro...
what is the ip address for it's network/ethernet card?
The external ip address (the one assigned by your isp) can be found at: http://whatismyip.com/
The internal ip address (differentiates the computers on your network) can be found by running the command prompt (start --> run--> cmd or start--> all programs --> accessories --> command prompt) and then typing int eh following command: "ipconfig" (without quotes). It will be the set of numbers in the form 192.168.something.something
Good luck, let me know if you have any questions
Dec 28, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
333 people viewed this tip
David Payne
David Payne
