Tip & How-To about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
"Unlock the super secret Administrator account for vista"
Deep inside the bowels of Windows vista, there's a secret Administrator account, and it's different from the normal administrator account you most likely have set up on your PC. This Administrator account is not part of the Administrator group. (Confused yet? You should be.) It's a kind of superadministrator, akin to the root account in Unix, and by default it's turned off and hidden. (In describing this hack, we'll always use the capital "A" for the secret Administrator account, and a lowercase "a" for a normal administrator account.)
In versions of Windows before Windows Vista, the Administrator account wasn't hidden, and many people used it as their main or only account. This Administrator account had full rights over the computer.
In Windows Vista, Microsoft changed that. In VISTA , the Administrator account is not subject to UAC, but normal administrator accounts are. So the Administrator can make any changes to the systemand will see no UAC prompts.
Turning on the Administrator account is straightforward. First, open an elevated command prompt by typing cmd into the Search box on the Start menu, right-clicking the command prompt icon that appears at the top of the Start menu, then selecting Run as administrator — or just use the shortcut you created in the previous hack.
Then enter this command and press Enter:
Net user administrator /active:yes
From now on, the Administrator account will appear as an option on the Welcome screen, along with any user accounts you may have set up. Use it like any other account. Be aware that it won't have a password yet, so it's a good idea to set a password for it.
If you want to disable the account and hide it, enter this command at an elevated command prompt and press Enter:
Net user administrator /active:no
HOPE THIS HELPS.
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
Administrator password to login not working
Microsoft's latest operating system, Windows 7, and its predecessor, Vista, offer a new layer of security that is different from previous releases, such as XP or 2000.
The earlier Windows versions treated all users as system administrators by default. With Windows Vista and 7, all accounts are treated as limited users.
The User Account Control utility provides elevated permissions when required and prompts users for those permissions.
You can control UAC behavior in Windows 7 so it does not prompt you for these permissions.
Start your computer with Windows 7 and log in as you normally would. Your desktop should appear, and any background applications should be closed.
Click the Windows "Start" orb at the lower left corner of your screen.
Click your account picture at the top right of the menu.
You will be presented with a window that allows you to make changes to your user account.
Click the link that says "Change User Account Control Settings."
Look for the User Account Control options slider.
The default option of User Account Control is to notify you only when programs try to make changes to your computer or you install new programs.
The option directly below that does the same thing but does not dim your desktop.
The "Never Notify" option at the bottom of the list eliminates the prompts for permissions.
Move the slider to the bottom of the options window.
Click "OK."
You may be prompted one last time from User Account Control to confirm your settings and reboot your computer.
or
Log in as an Administrator on Windows 7
If you've recently upgraded from Windows XP to Windows 7, you're probably wondering how to log in as an administrator. In Windows XP, the administrator account was clearly visible from the log-on page, but it's no longer there in Windows 7.
Although there is an administrator account, it must first be enabled with the Windows command prompt before you're able to use it. Enabling the administrator account lets you troubleshoot problems with programs on your computer.
Click on the "Start" button, and then type "command" into the search bar.
Right-click "Command Prompt" when the results appear.
Click "Run as Administrator."
The command prompt opens.
Type "net user administrator /active:yes," excluding the quotation marks.
Hit "Enter."
Click "Start," and then click "Switch User." Click the "Administrator" icon to log in.
Aug 04, 2013 | Computers & Internet
no administrator account showing
To show administrator account press ctrl alt del at the same timess 3 times on startup.
Oct 14, 2008 | Microsoft Windows Vista Ultimate Edition
how do i login on as administrator on my computer?
Login With the Administrator Account in Windows XP Professional
Click the "Start" menu and then click "Log Off."
Click "Switch User" when the prompt screen opens.
Press "Ctrl," "Alt" and "Delete."
Click on "Administrator" when the "Log on to Windows" screen pops up. Type in the administrator password, if applicable.
Click "OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and allow it to continue through its startup process. By default your computer will simply load directly to the primary user account (usually the administrator account), but if there are multiple users on the system it will load to the account login screen.
Use the mouse to click on the administrator account from the list of available accounts to log on. This step is only necessary if you've customized Windows Vista with more than one account or you have set the operating system to load the login screen first.
Enter the password required in the password field to log on to the administrator account.
Click the "OK" or "Log On" button once you have entered the password. This button may be labeled differently depending on the version of Windows Vista or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows Vista environment by clicking on "Start" and then "Log Off." As soon as you have logged off, you will be returned to the login screen where you can choose the administrator account from the available list.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Compaq tc4200 Tablet PC
gpedit police
AMSv2010 is now Available in my Web
Visit: http://naldo-project.weebly.com
It's a True Windows Solutions 100% Secure and Tested
Over 500 Administrator Restriction and Secret, Video Capture, iPod, Secret Panel, Internet Explorer Inside, Windows Registry, Windows Service, Restrict Devices, Backup Options, Screen Capture, User Manager, Legal Notice Caption and Text, System Information, Control Panel, Delete Files, Copy & Paste, NotePad, View IP, Windows Time, Keyfinder, Memory Information, Ad or Remove Programs, Startup List, View Restriction from System and Explorer, All Groups Policy Management (GPEDIT), All MMC Restrictions, Shutdown Timer, Shutdown, Hibernate, Restart, Logoff, more..., MDI Parent View Option, Task Manager Inside, Keyloger, Hidden and View Files, See the Video... more... more... more.
* Protect this Software with Password and Secure Password, Startup Option, Icon Tray Option*.
It's a Administrator Perfect Software and Tool
***Recommend this program to your friends***
by Naldo (AMSv2010 Developer, Designer, Author) Future MVP ((Most Valuable Professional) / Puerto Rico and Expert in Administrator Restrictions for Windows XP PRO, HOME, Vista and Windows 7 BETA in test and specifically to test Windows 7 has several restrictions.
Jan 13, 2009 | Microsoft Windows XP Professional With...
Cant restart Vista
To activate the administrator account in Vista, follow these instructions:
  1. Logon to Windows Vista with normal user account username and password (must belongs to Administrators group).
  2. Click on Vista Start button, and type cmd in the Start Search box.
  3. Right click on the Cmd rand select Run as Administrator
  4. In the Command Prompt window, type the following text at the command line to set a password for administrator account.
  5. net user administrator (password)
    Replace password with the actual password string that you have chosen. Press Enter when done.
  6. Next type the following command and press Enter to activate and enable Administrator account: net user administrator activate:yes
  7. The process should completed with the following message: The command completed successfully
    If not success message is returned, repeat the process again.
  8. Logout from Vista by choosing Log Off or Switch User.
  9. Click on Administrator icon and logon with the password you selected. Now view system logs to see what errors were gererated.And run a good virus scanner
Jan 06, 2009 | Computers & Internet
345 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
