Tip & How-To about Cameras
Tips for greater Pictures
Position The Horizon
Where you place the horizon in the shot affects what exactly is emphasized. to indicate the land, use a high horizon. To show the
sky, use a low horizon.
look for Details
A shot of an entire sequoia ranking just looks like a tree. But a shot of simply the tree's wide base, with a person for scale, is greater robust.
Use Proportion
think the frame divided into thirds, both horizontally and vertically, as getting Tic-Tac-Toe board. Always centering your subject can get dull. Use the Rule of Thirds to add variety and interest.
Add Depth
Add tips that could guide the eye. If your subject is a distant mountain, add a person or a tree in the foreground. A wide angle lens can exaggerate this perspective.
Consider Variety
involve landscapes and folks shots, close ups and broad angles, better weather and bad weather. Take personal shots that remember the ? friends which you meet, your hotel/campsite, transportation, street or hiking signposts
Include People
Photographs solely of landscape and rocks are enjoyable to take but often dull to look at. If there's no one around, include yourself using the self-timer
Cameras Logo
Busy indicator on all channels except WX. Unit is Standard Horizon GX1265X
It sounds as if your squelch is open. Turn your squelch control until any noise from the speaker drops out. Your busy indicator should go out.
May 02, 2016 | Standard Horizon Radio Communications
2000 Land Rover Discovery 2 hard to start during this winter season
Aside from building a garage or installing an engine block heater I have used this trick in the past on my 98 RR HSE. It may work for you if the starting issue is simply temperature related. Placing a shop-light or shielded work light underneath your block at night will produce just enough heat in many cases to overcome the slow starting problem.
Other possibilities may be under powered/weak battery. The rovers are known for high cranking amp demand and a weak or mismatched battery could certainly cause this problem. On the outside chance that it may be fuel delivery related you might try priming your fuel injection prior to cranking. Do this by turning key to position 2 (or last position before crank) wait til all the bells and whistles stop usually about 3-5 seconds, and repeat a couple times. If this is helpful, the bad news is it may be indicative of mechanical issues on the horizon.
****SAFETY NOTE***** PAY ATTENTION TO LIGHT PLACEMENT MAKING SURE NOT TO PUT IT IN PATH OF OIL LEAKS.
Hope this helps.
Dec 11, 2013 | 2000 Land Rover Discovery
1985 PLy Horizon distributor rotor position
Find the end of the plug wire for cylinder 1. Place the plug wire into the distributor cap. Rotate the Crankshaft until Cylinder #1 is TDC. align the rotor in the distributor cap with plug wire number 1.
Nov 23, 2008 | 1985 Plymouth Horizon
1,829 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
