Tip & How-To about Computers & Internet
MTS to DV Converter for Mac to MTS,M2TS, MKV, MOD to DV on Mac OS
High-definition video, or HD video, refers to any video system of higher resolution than standard-definition (SD) video, and most commonly involves display resolutions of 1280×720 pixels (720p) or 1920×1080 pixels (1080i/1080p). HD video, as opposed to its specific applications in television broadcast (HDTV), video recording formats (HDCAM, HDCAM-SR, DVCPRO HD, D5 HD, AVC-Intra, XDCAM HD, HDV and AVCHD), the optical disc delivery system Blu-ray Disc and the video tape format D-VHS.
HD video contains H.264/AVC, TS, TP/TRP, AVCHD, MKV, etc. Even though you can enjoy HD video on Mac iMovie, iDVD, Quicktime, Youtube, etc, but not all the HD videos will be compatible with Mac.
If you want to enjoy and edit HD video such as AVCHD MTS, M2TS, Camcorder MOD, MKV, etc in FCP, in iMovie, iDVD on Mac, you'd better convert these HD video to DV (direct to digital, easier to be edited on Mac) or convert HD to MOV, MP4 for Mac.
Now, Doremisoft HD Video Converter for Mac can convert HD videos like MTS, M2TS to DV, TS to DV, MKV to DV, MOD to DV, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD etc to DV for Mac iMovie. It can also transfer regular videos such as AVI, ASF, MPEG1, MPEG2, MPEG4, MOV, FLV, 3GP, 3G2, DIVX, M4V etc. to PSP, iPod, iPad, iPhone, Blackberry, Creative Zen, etc.
How to convert HD video to DV for Mac OS(Snow Leopard included)? Only 3 simple steps for you to convert HD video to DV on Mac.
Step One: Input HD Video to Mac HD Video Converter
Click "Add File" to upload your HD files from your Mac hard drive or desktop to HD Video Converter for Mac after you launched it.
Step Two: Select DV as Output Video Format for Mac
Press the "Profile" button to open the drop-up list to choose DV as the output format for Mac iMovie, iDVD, etc.
Step Three: Start to Convert HD video to DV on Mac OS
Click "Start" to convert HD video such as AVCHD MTS/M2TS, MKV to DV with Mac HD Converter for Mac. And you can check and enjoy converted HD videos on Mac after conversion finished.
Tips: If you want to edit HD video on Mac, you can refer to edit HD video on Mac to see more details.
Related: How to Import HD videos to iMovie and edit HD video in iMovie on Mac?
Computers & Internet Logo
Is this TV digital
This is not a digital TV. This TV has only an NTSC (analog) tuner. A converter will be needed to tune digital broadcast TV stations, your CATV or satellite company supplies a converter to allow this set to display programs.
The display is limited to "480P" resolution, called "Enhanced Definition", which is a step up from the traditional NTSC standard of "480i" resolution or "Standard Definition". ("P is "progressive scan" and "i" is "interlaced scan"). Progressive scan provides a better picture quality when compared to interlaced scan images. High Definition or "HD" is a signal that contains data that allows display of images with 720P, 1080i and 1080P resolutions (the larger numbers indicate more information, or higher picture quality). Your TV will receive all signals, SD, ED and HD, but will down convert to ED. Signals can be brought into the set via 2 composite-video connections, 1 each component- and S-video, an RF antenna/cable-box/VCR input, and a 15-pin D-Sub analog RGB input. More info can be found here.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 01, 2011 | Philips 15PF7835 15 in. LCD Television
how big is hd?
High-definition television (or HDTV) is a standard with higher resolution than normal T.V.
High-definition refers to any video system of resolutions of 1280×720 (720p) or 1920×1080 (1080i or 1080p).
Your Dell Inspiron 1525 PC Notebook has a 15.4-inch WXGA (1280 x 800) CCFL TrueLife (glossy) screen.
You will be happy to know that your screen is a HD screen!
I will look forward to your feedback and positive rating.
Sep 10, 2010 | Dell Inspiron 1525 Notebook
NO HIGH DEFINITION
  • HDTV capable: Yes (up to EDTV, 480p)
  • Jul 10, 2008 | Akai PT5492S 54" Rear Projection...
    147 people viewed this tip
    David Payne
    David Payne
