Tip & How-To about Hand Tools
Fiberglass/Mesh Tape Mythe
I've heard people say many times, " When I finished the drywall on my room addition, I used Mesh Tape
www.all-wall.com/Categories/Fiberglass-Mesh-Drywall-Tape/Thin-Drywall-Mesh-Tape
on my seams and inside corners". Well, I would strongly recommend that you use Paper Tape instead:
www.all-wall.com/Categories/Drywall-Joint-Tape
along with All-Purpose Compound: www.usg.de/index.php?id=1357
Even though Fiberglass/Mesh Tape is much easier to apply than Paper Tape, you should not use it because it has a greater tendency to crack when applied to New Drywall seams; unless you use Easy Sand 45, 90, or 220.
www.lowes.com/pd_11778-325-384210_4294864808+4294851233_4294937087_?productId=3009562&Ns=p_product_prd_lis_ord_nbr'0''p_product_quantity_sold'1&pl=1¤tURL=%2Fpl_SHEETROCK%2BBrand_4294864808%2B4294851233_4294937087_%3FNs%3Dp_product_prd_lis_ord_nbr'0''p_product_quantity_sold'1
The different numbers ( 45, 90, 220) indicate the amount of time, ( in minutes), that you have to work with this material before it starts setting up on you. TIP: I would not recommend this material if you are a beginner! The consistency of this material varies as time goes on, becoming thicker and thicker.
Mesh Tape is good for many other uses though. Such as, a fracture in the drywall, patching around electrical boxes, applying to corner bead as a strengthening material, or removing old tape and re-taping old rough seams in a rehab house.
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power-HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Drywall/Sheetrock/Gypsum Wallboard
Hand Tools Logo
drywall repair
Just saw your question but no answer. Sorry about the repair on the glass tape. Crack are pretty common with mesh tape, especially if the mesh was covered with premix all purpose compound. Mesh tape should be covered with setting type compounds. More info can be found on the tapebuddy.net how-to manual. They cover the reasons for the different compounds.
Jan 24, 2014 | FibaTape Drywall Crack Repair Tape...
what can replace that tape, if i can't find it what i can use ineteat
just go to any hardware store and buy any drywall mesh tape on that width (2" - 50mm) and approximately same length (50yds to 60yds), virtually all of them have same internal diameter, therefore you should not have any problem with putting it into the dispenser.
do not bother with brandname! generic tape work as well and is half the price! tapeis glued only to tack to the wall, then mud is holding it.
Dec 17, 2013 | Dap 9140 - Drywall Mesh Tape, 2 In x 60...
fixture for curtainrail wentthroughplasterboardbig hole now help.me fix please
Hi, W/D here.
It takes about 4 days for a good patch to be made. You can buy the materials in small quantities at the hardware store, so it won't cost much at all for a small hole, and a little more for a larger one.
For a hole smaller than a tennis ball, you can press newspaper crumpled loosely into a ball into the hole, as much as you need, to build the hole up to just below the surface, then cover with overlapping layers of drywall mesh tape. The directions for a larger hole follow, and you can skip the first parts of it if you do not need them (if you are using the newspaper method.). With this method (newspaper) the most important part is to remember that the first coat of spackling is just to anchor the tape and bridge the repair, no more.
The easiest way to repair a larger hole in wall board:
1. Cut a piece of new wall board larger than the hole you want to repair.
2. Take your wallboard "patch and hold it over the hole. Draw the outline of the patch on the wall.
3. Using a drywall saw, cut out the outline of the patch on the wall.
4. Cut a piece of wood longer than the hole is tall, by about 4". Measure back from each end 2".
5. Start a drywall screw 1" above the patch outline, centered. Align the wood in the hole with the lines you made on it at 2" back from the ends. Screw the drywall screw into the wood. Do the same at the bottom. You'll want the drywall screw to be below the surface while trying not to break the paper surface of the drywall.
5. Fit your patching piece into the cavity, and, depending on how large the hole is screw through the patch and into the wood with one or two drywall screws.
5. Using self-adhesive drywall tape, tape the crack around the patch, overlapping at the corners.
6. Use pre-mixed drywall spackling with a 4" putty knife to apply the first coat of drywall spackling to the patch. The aim here is to secure the new drywall to the old, so you need to use the putty knife to press the spackling into the crack, and lightly coat the drywall tape. If your screws that were used to secure your wood to the back of the old drywall are outside of the tape, press the spackling into the screw dimples as well. If you hear a "ticking" sound as you pass over the screws with the spackling, the screw isn't set deep enough. Give it another turn or so, until you don't hear it tick when you pass over it with the knife. Let all of this dry for 24 hours. Clean your tools, and dry them.
7. The next day, sand any burrs that stick out, but sand lightly, trying to taper the patch out onto the old wall. Don't be too particular, as there is still a ways to go. Using the drywall knife and spackling, re-coat the patch, blending more onto the wall, and leaving a little more material in the mesh of the drywall tape. The cracks should be refilled, as they'll have shrunken in overnight, so this is all done at the same time. Don't over-work it, just give it a good coating, and leave it alone. The screws that you previously spackled will get another coating at this time as well. You're done for the day, clean and dry your tools.
8. The next day, lightly sand the burrs, again feathering a bit onto the wall. Try to remove the dust from sanding with a dry cloth, lightly brushing the patch and wall. This should be the final coat today. Lightly apply your spackling, feathering it out onto the wall. The aim here is to make the finished repair invisible to the eye, so feather out onto the wall at least the width of your blade, if possible. You can fill the screw holes again as needed, feathering the spackling out from the screw dimples onto the patch and wall. Done for the day. Clean and dry your tools.
9. Day 4. Sand the patch, feathering out from the patch and across the patch. It should appear relatively flat to the eye, with the cracks and screw holes filled and feathered. No tape should be sticking out. It will all appear smooth. It is ready for matching paint.
Hope that this was helpful.
Best regards, --W/D--
Feb 03, 2011 | Washing Machines
706 people viewed this tip
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
