Recovery Methods for SanDisk/Sansa Mp3 Players
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Was this helpful?16 people thought this was helpful
Comment #1
posted on May 18, 2009
By
st3curl
Rank: Apprentice
Rating: 0%, 0 votes
i could use some extra help, see, my player says that its memory is mostly full, but i cant find a single one of my files on it, and ive searched the thing through and through
Comment #2
posted on May 01, 2009
By
p2412
Rank: Apprentice
Rating: 0%, 0 votes
Now that's an answer! Thanks big time
Comment #3
posted on Apr 03, 2009
By
irgeek
Rank: Apprentice
Rating: 70%, 1 votes
Beautiful! Just the post I was looking for! Worked like a champ! Thx!
Comment #4
posted on Mar 01, 2009
Thank you for your help. None of these tips helped. Maybe it's just dead. It sad that it didn't even last a year.
Can you Help with these MP3 and Digital Media Players problems?
SanDisk Sansa e250 MP3 Player
I plugged my sansa into someone elses Apple to charge,...
the MP3 player is frozen on "refresh database"...
it won't turn on even when charging
Not enough space for music DB Please free 4MB?
down loading on the sansa clip
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE
We can...
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
