Tip & How-To about Microsoft Windows XP Home Edition
Windows XP: How to run Disk Cleanup
Disk Cleanup is a file deletion utility that comes pre-installed in most Windows operating systems. It is a good, simple tool to use to free up disk space and to get rid of files that you don't need. Here are the steps to run Disk Cleanup in Windows XP:
A. Click on the Start button.
B. Click on My Computer. (If there is no My Computer icon on your Start menu, you can typically find it on the desktop.)
C. Right click on your hard drive (usually, this will be the C: drive) and select Properties.
D. Under the General tab, click the button labeled Disk Cleanup.
E. The program will take a little while to load while it figures out file sizes and locations. Once it finishes, the Disk Cleanup window will appear. The files you can delete to reclaim hard drive space are grouped by type (Temporary Internet Files, Office Setup Files, etc.) Next to each file type will be the amount of disk space you'll gain by deleting those files, and underneath the file types you can see a description of the currently-selected file type. Decide which files you can delete, and put a check mark next to those types. (If you're not sure which files are included in a certain group, you can click the View Files button below the description to see the exact files in question.)
F. Once you've selected all of the file types you want, click OK.
G. A confirmation box will appear; choose Yes to remove the files. Depending on how many files you chose to delete, the removal may go quickly or it might take a minute or two. Once it finishes, the Disk Cleanup window will close.
Microsoft Windows XP Home Edition Logo
YL9Q154298speedmaxpc serial key
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same timeputting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
and download and install either or all of these
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://superantispyware-free-edition.soft32.com/
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html
5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
Delete some stubborn files
http://www.malwarebytes.org/fileassassin.php
http://advanced-systemcare.soft32.com/One-Click Free System tool
this should speed up your computer
Jan 13, 2014 | Computers & Internet
My Desktop is very slow and i want to reset it?
Your desktop probably just needs a good clean and tune up >?
And you might want to add some more ram.
Open Disk Cleanup by clickingstartall programsaccessoriessystem tools and then clicking Disk Cleanup.
or if you still just want to reset it use the system restore
System Restore
You can use the System Configuration utility to perform a system restore.
There are three possible restore points:System checkpoints that Windows schedules
Manual restore points that you specify with the System Configuration utility
Installation restore points that occur before you install a program or a serviceyou can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points.
Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
HP Desktop factory settings
The HP Recovery Partition that comes pre-installed on most new HPs is like built-in insurance if your system becomes unstable or fails.
If the problem is severe enough, you may not be able to start the HP Desktop Recovery Manager from Windows but you can start it manually by following the steps below.
Disconnect all peripheral devices and power on the computer.
Press the F11 key after the computer first powers on to start the HP Recovery Manager.
Follow the on-screen instructions to back up recoverable files on the hard drive to an external drive or media.
Continue following the instructions to recover the hard drive to its original factory condition.
Click "Finish" when the recovery is complete.
Reconnect devices and reboot the computer.
Reinstall software and update Windows and HP to current settings.
Performing an HP System Recovery (Windows Vista)
Dec 08, 2013 | HP Computers & Internet
slow computer
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
Open Disk Cleanup by clicking startall programsaccessoriessystem tools and then clicking Disk Cleanup.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
http://advanced-systemcare.soft32.com/ One-Click Free System tool
Sep 11, 2013 | Avanquest Fix-It Utilities 9 Professional...
deep system analysis freezes up at 52% has been running for 24 hours why does it do this? with system mechanic standard and I have vista.
Windows 7 chkdsk
Sep 10, 2013 | IOLO System Mechanic Premium Full Version...
computer is slow
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 08, 2013 | Computers & Internet
995 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
